1 members (Hotrod Lincoln),
130
Mod | | | Forums66 Topics128,143 Posts1,056,494 Members48,442 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2007 Posts: 79 'Bolter | | 'Bolter Joined: Dec 2007 Posts: 79 | Did a search,and all the gas gauge problem. So I apologize for asking again. Been working on a 1949 1/2 ton installed a 235, a complete wire hardness for 12 volt put in a new sending unit and 12 volt gauges, had the tank out and cleaned it. Just now got to the place I could put gas in, was mainly looking for any leaks in the line connections. Put about 4 gallons in , turned the key on and nothing, no movement at all, gauge stayed on E, Took a test light reached up touched the E post to ground got light with the key on. So I took out the sending unit and tested with an ohm meter, tested ok. My question is I touched the E post with the key off to ground a complete circuit , touched the sending post to ground a complete circuit. Also tested the sending wire at the tank with it disconnected from tank a complete circuit to ground . By the way the hot is connected to the Empty post .Test the tank to ground good , have a wire to ground. Is it possible that the E post is taking the 12 volts straight to ground? Any help much appreciated ! Thanks
| | | | | Joined: Feb 2019 Posts: 4,486 AD Addict & Tinkerer | | AD Addict & Tinkerer Joined: Feb 2019 Posts: 4,486 | This post, thanks to Volfandt, should help explain how the gauge should work. [Click]
Phil Moderator, The Engine Shop, Interiors and Project Journals1952 Chevrolet 3100, Three on the Tree, 4:11 torque tube Updated to: ‘59 235 w/hydraulic lifters, 12v w/alternator, HEI, PCV and Power front Disc BrakesProject JournalsStovebolt Gallery Forum | | | | | Joined: Jul 2018 Posts: 51 'Bolter | | 'Bolter Joined: Jul 2018 Posts: 51 | I see you put in a new sending unit BUT is the sending unit for 12 volts, if not it needs a resistor I think. | | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | Senders are not voltage specific
He stated he has 12 volts and a 12 volt gauge. No resister needed.
If this is a new 12 volt gauge there are 2 common issues to check.
Good grounds, and clearance at the needle. The reproduction 12 volt gauges have a needle that sits higher than original. Sometimes it get pinched by the bezel. So check for clearance.
Another common error is the ground. There is a metal tab on back of the fuel gauge with a solder glob..this need to contact clean metal in the cluster. If you refurbished the cluster and painted it you'll need to clean the paint off so the back of the gauge touches metal
Let us know what work you have done to this gauge. There is more troubleshooting to do.
| | | | | Joined: Dec 2007 Posts: 79 'Bolter | | 'Bolter Joined: Dec 2007 Posts: 79 | Going to have to pull the gauge again. I pulled the sender unit again and hooked it up to the sending wire and with the key on, moved the float manual nothing. And I know I have power to the E terminal, so the gauge is not grounded ,or I have already smoked the gauge. | | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | I pulled the sender unit again and hooked it up to the sending wire and with the key on, moved the float manual nothing.. Did you ground the sender for this test? Sender also need to be grounded even for a test. If the gauge was properly grounded but the sender was not the gauge would go to full. Not fun pulling the gauge in and out the dash | | | | | Joined: Dec 2007 Posts: 79 'Bolter | | 'Bolter Joined: Dec 2007 Posts: 79 | The sender was grounded, maybe the gauge is not, I've never had the needle move at all . I know the gauge is no fun to pull ,but better now then latter, I want the gauge to work .Maybe the needle is stuck on the bezel. Thanks | | | | | Joined: Jan 2018 Posts: 189 'Bolter | | 'Bolter Joined: Jan 2018 Posts: 189 | I've mentioned this before, but before I even thought of trying to get the original gauge to work, I gave up, and just use my Fluke meter to check fuel level. It actually works very well since it's so accurate using 10ths of and Ohm. You can calculate fuel mileage even on short trips. On a 17.5 gallon tank you just read the ohms, and multiply it by .583333. Tells you exactly the fuel level in gallons. Pretty much how they do it on new cars.
