4 members (JW51, rfs56trk, Cosmo, 1 invisible), 119 guests, and 3 robots.
Topics128,080
Posts1,055,956
Members48,430
#1346016 02/11/2020 8:24 PM
Found these online to convert to 22.5 tire size. I have 5 lug on my 1939 2.5 ton. Has anyone tried these?
http://www.wheelsnowinc.com/catalog/index.php?brandID=2&diaID=14
Crusing in the Passing Lane
What is the boltpattern diameter? These are stud piloted. Yours should be hub piloted, are your rear wheels 10 bolt? If so, you have 5/10 on 7.25" hubs. Earliest tubeless 22.5 tires and wheels came on late '50's GM 1.5 ton trucks, hard to find, look on farm trucks. If found, need thin spacer ring(easily made) to fit to old axles. 19.5 wheels are common, look under nourished on this size truck.
Ed
Some people have used the custom wheels from Wheels Now. They are a universal wheel that get the bolt pattern drilled to suit whatever application. Because of that they have a larger than average flat center that looks odd and in my opinion quite undesirable on an old truck.
If you just want a good wheel then it's probably OK... except they are also way to wide for many old trucks. (compare width to your original)
If you want a wheel to look good find an older/original wheel option.
1952 Chevrolet 3800 pickup
---All pictures---
None of those would work, needs to be hub piloted an 10x7.25 bolt pattern.
These adaptors look like they would work for those who have 5.25 hub pilot:
https://r.search.yahoo.com/_ylt=Awr9DtP4O0Re7IgA7Slx.9w4;_ylu=X3oDMTByYnR1Zmd1BGNvbG8DZ3ExBHBvcwMyBHZ0aWQDBHNlYwNzcg--/RV=2/RE=1581558905/RO=10/RU=https%3a%2f%2fwww.ebay.com%2fitm%2f10-Lug-10x7-25-to-10x285-22-5-24-5-Semi-Wheel-Adapters-1-5-Thick-For-Rear-%2f263692036255/RK=2/RS=Q.mtNzEuL7Yskx_WsdsILNzOc8E-
Vehicle Bolt Pattern: 10 x 7.25"
- Wheel Bolt Pattern: 10 Lug 10x285mm (Fits 22.5" and 24.5" rims)
- Thickness: 1.5" (plus 1.5" hub ring)
- Center Bore: 5.25"
- Adapter Studs: 22mm x 1.5
- Lug Nuts: Drilled to fit 5/8 vehicle studs (lug nuts not included)
- Material: 6061-T6 Aircraft Aluminum
- CNC Machined
I got 2 of these for my front wheels on my 72 c-50. Got tired of rooting around looking for originals that are one piece. They work fine. They do look a lil different but they still roll fine and make the truck useable. Now if your a show truck guy you probably wouldnt want them. But one thing I should say is my front driver side wheel does rub the steering box linkage arm when I have the steering wheel all the way cranked to the right like when backing up, but it just barely touches once my brand new tires wear a bit it will probably be fine. Or I may have went with to tall of a tire for it . But either way there isn't really any issues when driving cuz I have never had the wheel cranked like that when driving only when backing up trailers or the truck into tight spaces. And not to mention wide right turns keeps it safe.
But one thing I'd say before spending 500bucks on new front rims. Then another 1k on tires to put on them. If you have any junk yards near you look around for trucks like yours and see if they have whole axles with good serviceable rims and swap. I wish that's what I did. Cuz i had widow makers all the way around bought the front wheels cuz my windows were worn and then I had rear axle issues and did a swap and got a rear with dayton rims and decent tires for 200 bucks and could have got the front axle with same rims for 150 with decent tires. So I could have saved a lot of money going that route. Might be alot of work to change axles but to save 1200bucks I think it might be worth it.
Here's a pic.... they will be black soon.
These are my rear wheels... guess I'll clean them up and use them
Those dont look like split rims but I could be wrong. They are definatly old rims tho. I also didn't realize you were working with such an old truck so your probably not gonna find many salvageable donors that old but idk, you canadians could hold onto stuff longer then us Americans Haha were kinda loosing it down here.
I like em. Clean em up and use them. Maybe splurge abit and get them sandblasted.
I think you're right Glenn
Well i got really lucky, I came across a local deal on 4 x 8.25-20 Goodyear's for the rear end ... when we were loading them up I saw he had 2 x 7.50-20 steer tires as well so I bought those too. The guys dad used to restore old IH trucks before he passed and he had these tires in his barn. All of them are brand new... next up is my carb rebuild and 12v conversion grin
Are those tires new like made in 2019 or new like made in 1990?
Mike B smile
Mike Boteler
1956 Chevy 3100 Resto Rod
1952 Willys M38 Army Jeep
1983 Jeep CJ7 Laredo
1984 Jeep CJ7
Silver Spring, MD
Mike B smile
Def not 2019 they are old stock but been in a horse stall for years. How do you decipher dot code dates on these?
"How do you decipher dot code dates on these?"
from Tire Rack website
2006 or 1996?
T 336 ?
3 digits?
4 digits from 2000 onwards
3 digits before 2000
Do tires go bad in dry storage? They're in great shape
They can depending on the rubber compound. 🛠
