4 members (DadsFirstPickup, Gray_Ghost, cspecken, 1 invisible), 178 guests, and 5 robots.
Topics128,087
Posts1,056,112
Members48,434
#1347564 02/23/2020 5:10 AM
Is there a difference between the 1941 style and 1946 style headlights used on the half ton trucks? It seems like the parking light style on the 1941 lights is different from that used on the later trucks. If this is the case, are the parking light housings interchangeable? Thanks!
Crusing in the Passing Lane
'41 lights used Pontiac lenses for the small one, might not be available, ask Jim .Carter.
Ed
I got mine from Jim Carter, they are plastic. Dave
1941 Chevy
"First rebuild - complete!"
Follow the story in the DITY
1941 GMC resting peacefully
1946/1947 Chevy Street rod on s10 frame complete
1945 GMC panel truck in line for restoration
1941 Plymouth stock complete
1941 GMC COE in restoration process
Read his Project Journal
1941 Chevy Coe uncertain future resting now
Yes, there is a difference. the 46 parking light housing is a one piece unit with a smaller lense. Mine are glass, some are plastic. The 41 housing is two pieces with a longetr lense. I dont think you can get the 41 lenses in glass anymore. I'm perty sure you can use either of the the housings on your headlight buckets. They are pretty much the same shape.
Hope this helps
George
