1 members (Gray_Ghost), 83 guests, and 2 robots.
Topics128,080
Posts1,055,956
Members48,430
#1347756 02/24/2020 4:51 PM
I haven't been able to find much info on the operation of the Garwood dump bed on my 1956 6100. Does anyone know what the difference is between the two levers in the picture?
Also is there any good documentation on the operation of hoist?
Crusing in the Passing Lane
Crawl underneath and turn driveshaft by hand while exercising levers.
Ed
if the garwood controls are like other hoists, one lever engages the PTO and the other engages the hydraulic pump.
Oldbolter
1959 Apache 3800 dually flat bed/dump with 261
1956 3800 dually flat bed/dump with 235
1957 3600 flat bed, 350 engine, 700R4, PS, disc brakes, 14 bolt rear with 4.11 gears
I agree with oldbolter and Ed, you need to crawl under the truck and see whick is connected to the PTO on the side of the trans and which one is linked to the hydraulic pump control valve.
If you get your hoist working, make sure you always block the bed from falling if it's in the raised position, many guys have been crushed when the bed came down while they were servicing the truck.
Mike B smile
Mike Boteler
1956 Chevy 3100 Resto Rod
1952 Willys M38 Army Jeep
1983 Jeep CJ7 Laredo
1984 Jeep CJ7
Silver Spring, MD
