| | | Forums66 Topics128,180 Posts1,057,067 Members48,460 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2013 Posts: 55 'Bolter | | 'Bolter Joined: Jul 2013 Posts: 55 | Hi All,
So I have a stock 57 truck straight 6 235 that does not have the horn wiring connected.
1. Has an original steering wheel with nos contact plate and button (I installed )
2. The horn relay is installed on the firewall with the original connector hooked up to it.
3. My truck has only one horn mounted on the driver side near the radiator as original and has the stock connector hooked to it.
4. I see there is a black wire with fitted with a spade connector coming from the steering column just hanging there. Where does it suppose to be connected?
Any help would be appreciated. If anyone has pics from under the horn cap and where that black wire coming from the column goes that would really help me out.
Thanks in advance.
LOS ANGELES, CA
48 FLEETLINE AERO, 50 CANOPY EXPRESS
52 SUBURBAN, 57 BIG WINDOW Pickup, 64 Malibu CV
| | | | | Joined: Feb 2019 Posts: 4,506 AD Addict & Tinkerer | | AD Addict & Tinkerer Joined: Feb 2019 Posts: 4,506 | Here is a recent post on that subject that may help. [Click]The wire you found coming from the steering column is connected to the horn button on your steering wheel, which makes the final ground to sound your horn.
Phil Moderator, The Engine Shop, Interiors and Project Journals1952 Chevrolet 3100, Three on the Tree, 4:11 torque tube Updated to: ‘59 235 w/hydraulic lifters, 12v w/alternator, HEI, PCV and Power front Disc BrakesProject JournalsStovebolt Gallery Forum | | | | | Joined: Jul 2013 Posts: 55 'Bolter | | 'Bolter Joined: Jul 2013 Posts: 55 | The wire coming from the column has a spade fitting. Where does it go to?
LOS ANGELES, CA
| | | | | Joined: May 2015 Posts: 11,146 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 11,146 | The wire on the column would go to one horn relay coil terminal, with power being supplied to the other coil terminal.
Kevin 1951 Chevy 3100 work truckFollow this saga in Project JournalPhotos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together. | | |
