0 members (), 40 guests, and 2 robots.
Topics128,030
Posts1,055,428
Members48,422
#1347203 02/19/2020 10:37 PM
Hi, I just got this 235 which I was told is a 1959 did a search found the head numbers 3836848 but could not find anything on the number by the dist F629JB any help would be great. Thanks Steve
The 3836848 head was used from 1956-1962 (and, maybe late 1955 and early 1963?)
F629JB
F= Flint Michigan engine plant
6 = June
29 = 29th
JB = ?
1959 truck codes
1959 car codes
find and post the head/block casting codes & head/block date casting codes
JB = 1960, 235, C-10 & C-20 with Powerglide
Mike B smile
Mike Boteler
1956 Chevy 3100 Resto Rod
1952 Willys M38 Army Jeep
1983 Jeep CJ7 Laredo
1984 Jeep CJ7
Silver Spring, MD
Mike B #1347248 02/20/2020 11:44 AM
Thank you I will do some cleaning and get some more numbers.
After some cleaning numbers between dist and draft tube are 3764476 and by the starter F269 no captains bars on the motor where the picture Tim posted. Thanks Steve
3764476 block casting code used on 235 truck engines from 1956-1962
F269 block date casting code
F = 6 = June
26 = 26th day
9 = 1959
That engine came from the factory with mechanical lifters.
Stovebolt engines casting codes and serial numbers.
The 848 head was introduced for the 56 235 car and truck motors. 261 truck motors used a different head. I have seen a few 848 heads over the years with casting dates in 55, and actually own one. But in every instance, those heads were cast later in the year, like late July/August through December of 55. I have never seen one earlier then July of 55. Those heads were all for the 56 model year (GM generally stopped production of the 55s around the end of August, retooled in September and began 56 production around end of September beginning of October).
Your head looks like end of June so there was theoretically 60 more days of production left for late 55 models. I don't know the lead time between the casting of the head, and the building and delivery of the motor, but my vote is that it is more likely a head for a 60. But hey, you never know.
Mike
Thank you for all that info a big help! Steve
