7 members (Nick in Manitou, 66flea, Cletus1950, Hotrod Lincoln, 2-Ton, Jay R, TooMany2count),
333
7
Mod | | | Forums66 Topics128,158 Posts1,057,025 Members48,460 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2005 Posts: 481 'Bolter | | 'Bolter Joined: Jun 2005 Posts: 481 | I have a 3-speed manual transmission with an on-the-column shifter in my restored 1958 Apache 3100 pickup. Experiencing some gear grinding in 2nd and 3rd gears (after driving the truck long enough for things to warm up) and also it will occasionally jump out of 3rd gear when I am just cruising along.
Would like to know what is causing these things and see what I can see for a diagram/drawing of the transmission.
John | | | | | Joined: Apr 2005 Posts: 2,102 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,102 | If you have the standard Muncie SM318 3 speed transmission the problem can be one or all of the following: 2-3 speed clutch sleeve and related rings and cones.(AKA syncro drum assy). Worn shift fork, springs, balls, and side cover components. Worn energizer springs on 2nd and 3rd gear. Worn bearings. Contributing factors are bad u-joints along with sloppy shift rods and levers. Popping out of 3rd gear is a common problem with this series transmission. Fred
| | | | | Joined: Feb 2004 Posts: 29,870 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,870 | Add one more possibility- - - -loose trans to bellhousing bolts- - - - -I've seen it happen pretty often. Bad bearings and/or a worn 2-3 synchronizer is the most common cause. Jerry
| | | | | Joined: Apr 2005 Posts: 2,102 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,102 | Someone else suggested a worn pilot bushing in another post on this subject. I'll add rear output shaft bushing and front driveshaft yoke to the list. Lots of things to wear out on 60+ year old trucks. Fred
| | | | | Joined: Jun 2005 Posts: 481 'Bolter | | 'Bolter Joined: Jun 2005 Posts: 481 | All of you are loaded with good information. Thank you for your input. I am hopeful that I have found someone local that knows these old transmissions and can still work on them, especially mine. | | | | | Joined: Jun 2011 Posts: 5,096 Crusing in the Passing Lane | | Crusing in the Passing Lane Joined: Jun 2011 Posts: 5,096 | They are pretty simple, get some books and do it yourself, we all have to learn. I am sure you have a neighbor that might watch over your shoulder.
Ed
| | | | | Joined: Nov 2014 Posts: 70 'Bolter | | 'Bolter Joined: Nov 2014 Posts: 70 | For parts contact Southern Gear in Atlanta, they still have new shift forks, the input shaft nut and a shim with an offset in it that goes between input shaft and front bearing. The offset shim allows oil to still get to the front bearing and get a little more spline engagement of input sf/haft into the synchro drum in3rd gear. The owner Kenny is a wealth of knowledge on SM-318's since it was the first transmission they allowed him to rebuild way back in the late sixties.
ESum
| | | | | Joined: Jun 2005 Posts: 481 'Bolter | | 'Bolter Joined: Jun 2005 Posts: 481 | Thank you ESum. More good information. | | |
