3 members (Bill Hanlon, Hanks custodian, Nick in Manitou), 64 guests, and 3 robots.
Topics128,080
Posts1,055,953
Members48,430
#1346807 02/17/2020 3:17 AM
Trying to resolve a 45-50 mph vibration in my '60 with an sm420.. Removed the driveshaft to rule it out, and the vibration occurs in exactly the same way: in 4th gear at 45-50 mph. Don't suspect motor or clutch since thi only occurs in 4th. Transmission is not original to the motor (283). Replaced a very tired 3spd.
Any suggestions would be appreciated. Headed towards either a full rebuild kit, or finding another trans, but hoping I can find out what is wrong and save some money.
49 GMC 1/2ton (Work in progress)
66 Chevy II (Better than New)
TMayes #1346821 02/17/2020 5:59 AM
Ok, I have read this three times and cant figure out what you are saying here. You removed the driveshaft? How did you get it up to 45-50 mph then/
1953 Chevrolet 3100
In the DITY Gallery
Video of the 261 running
1964 GMC 1000
sstock #1346832 02/17/2020 1:37 PM
Speedometer cable terminates @ the transmission, not after. The transmission tail shaft shows 45mph whether the vehicle is moving or not wink
TMayes #1346838 02/17/2020 2:51 PM
Crusing in the Passing Lane
Is there a park brake on the rear of the trans that could have a piece broken out to cause unbalance?
Ed
TMayes #1346846 02/17/2020 3:34 PM
By and large the biggest rotational mass in this transmission is the giant first gear. It travels continually at the speed of the main shaft regardless of the speed of the truck or what gear it is in.
That said, a vibration could be caused by excessive clearance between the first gear and the main shaft. There is a check on this that requires the disassembly of the main shaft. It is measuring the rock of the first gear to be no more than .015.
Good time to inspect the friction ring and neoprene strip inside the diameter of the first gear for wear. Also, I have seen the second gear syncronizer ring retainer broken on a few transmissions that would cause the second gear synchronizer ring to flop around on the inside of the first gear, that could cause a nice noise and vibration too.
Steve
1953 Chevrolet 3100
In the DITY Gallery
1964 GMC 1000
TMayes #1346860 02/17/2020 4:39 PM
I've got a nice SM420 for sale, just came out of my GMC250
1950 GMC 250 Pickup
1965 Mustang Convertible
1972 K5 Blazer
1973 Buick Centurion 455 Convertible
TMayes #1346871 02/17/2020 5:25 PM
Offering parts for sale outside the Swap Meet Forum is not an approved activity. Please take it to PM or post in the Parts for Sale Forum. Thanks
