2 members (Peggy M, Otto Skorzeny), 97 guests, and 2 robots.
Topics128,052
Posts1,055,774
#1346765 02/16/2020 8:46 PM
rad
Offline
considering dropping the front and rear of the 49. don't want any drivability issues. will a 3 inch drop axel give me any driving issues? Is a 3inch too low for street driving? what all (parts) do I need for a 3 inch drop axel/ will everything bolt up?
rad #1346769 02/16/2020 9:13 PM
Rad,
What size tires are you planning? You need to calculate your scrub line! I am running 215/75 R15 with a 4” drop in the front without issues. I miscalculated the scrub line because I was going to get bigger rims. Ops! If I blow a tire my axle is 1/2” off the ground. If tire comes off the rim, my axle will be on the ground. It looks good, but I wish I would have stayed at 3”.
Look up dropped axle.com. Sid is a good guy! He has lowering blocks for the back along with all U bolts, shims, etc. he can also redo kingpins, etc.
Chris
rad #1346798 02/17/2020 1:26 AM
Crusty Old Sarge
Crusty Old Sarge
I also have a 4" drop axle from Sid on my 59'. With 15" wheels the 4" is really close to the ground, wish I had gone with a 3". Keep in mind that if you go to power steering you will need accommodate for the drop axle as well, caster, drag link and pitman arm. Good luck.
~ Craig
1958 Viking 4400
"The Book of Thor"
Read the story in the DITY
1960 Chevrolet C10
"A Family Heirloom"
