| | | Forums66 Topics128,049 Posts1,055,546 Members48,425 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2019 Posts: 33 'Bolter | | 'Bolter Joined: Dec 2019 Posts: 33 | considering dropping the front and rear of the 49. don't want any drivability issues. will a 3 inch drop axel give me any driving issues? Is a 3inch too low for street driving? what all (parts) do I need for a 3 inch drop axel/ will everything bolt up? | | | | | Joined: Jan 2013 Posts: 2,232 Moderator: Interiors, Texas Bolters, Name that Part | | Moderator: Interiors, Texas Bolters, Name that Part Joined: Jan 2013 Posts: 2,232 | Rad,
What size tires are you planning? You need to calculate your scrub line! I am running 215/75 R15 with a 4” drop in the front without issues. I miscalculated the scrub line because I was going to get bigger rims. Ops! If I blow a tire my axle is 1/2” off the ground. If tire comes off the rim, my axle will be on the ground. It looks good, but I wish I would have stayed at 3”.
Look up dropped axle.com. Sid is a good guy! He has lowering blocks for the back along with all U bolts, shims, etc. he can also redo kingpins, etc.
Chris
| | | | | Joined: Mar 2007 Posts: 3,378 Crusty Old Sarge | | Crusty Old Sarge Joined: Mar 2007 Posts: 3,378 | I also have a 4" drop axle from Sid on my 59'. With 15" wheels the 4" is really close to the ground, wish I had gone with a 3". Keep in mind that if you go to power steering you will need accommodate for the drop axle as well, caster, drag link and pitman arm. Good luck.
~ Craig 1958 Viking 4400"The Book of Thor"Read the story in the DITY1960 Chevrolet C10"A Family Heirloom"Follow the story in the DITY Gallery'59 Apache 31, 327 V8 (0.030 over), Muncie M20 4 Speed, GM 10 Bolt Rear... long term project (30 years and counting) If you don't like driving yourTruck, you won't drive yourTruck..| Living life in the SLOW lane | | |
