8 members (Southerntruck, Ponchogl, Cosmo, VicZ, Patina 54, Wally / Montana, Mike Burns, 1 invisible),
125
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,087 Posts1,055,977 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2015 Posts: 51 'Bolter | | 'Bolter Joined: Jan 2015 Posts: 51 | I’m replacing my king pins on my 1950 1/2 ton. I took them apart and found the top bushing on the drivers side froze to the pin and was spinning in the spindle. Now the new bushing slips into the spindle loosely. A new spindle will fix it if I can put my hands on one. I just took it apart tonight and haven’t had a chance to take it to a machine shop yet to see if they have some options. Any ideas? Thanks Don | | | | | Joined: Feb 2000 Posts: 5,210 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 5,210 | | | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | | | | | | Joined: Feb 2019 Posts: 4,476 AD Addict & Tinkerer | | AD Addict & Tinkerer Joined: Feb 2019 Posts: 4,476 | The 1/2 tons were not originally designed to be a press fit (like their big brothers, 3/4 and up) but more like a hand press fit. I recently did my ‘52, and the slop measured from .002 to .006 thousands and I used locktite 660 to secure the bushings. I haven’t put allot of miles on her but so far so good.
Finding steering knuckles in good shape is getting real hard and costly. If you can repair your’s, it would be real beneficial.
If you go that route, after inserting the bushings into the steering knuckle, insert the king pin to align the bushings, then let is set until dry before you assemble.
Phil Moderator, The Engine Shop, Interiors and Project Journals1952 Chevrolet 3100, Three on the Tree, 4:11 torque tube Updated to: ‘59 235 w/hydraulic lifters, 12v w/alternator, HEI, PCV and Power front Disc BrakesProject JournalsStovebolt Gallery Forum | | | | | Joined: May 2006 Posts: 934 'Bolter | | 'Bolter Joined: May 2006 Posts: 934 | As you wrote -- you can have new bushings made to fit by a local shop or by a retired hobbyist/ machinist. Ream or bore the spindle bore for over size bushings, fabricate new bushings, and hone to fit the new pins. Certainly not out of the realm of possibilities. Someone here on this site recently posted this - made their own - and honed to fit. May be more than what you intended to spend, but should last for years and years.
| | | | | Joined: Mar 2010 Posts: 10,275 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,275 | I am now curious to know what the outside dimension is for a 3/4 ton kingpin bushing. These bushings are designed for a press fit in the 3/4 ton spindles. If this dimension is larger than the hole in a 1/2 ton spindle, it seems like the 1/2 ton spindle could be bored to fit the 3/4 ton bushing. Then you would need to know what the inside diameter of the 3/4 ton bushing is to see if a 1/2 ton kingpin will fit inside of it. The 3/4 ton bushings need to be reamed to fit the 3/4 ton kingpins, so maybe they can be reamed to fit the 1/2 ton kingpin. So here is what we need to know to see if we can use 3/4 ton bushings to repair otherwise shot 1/2 ton spindles without the high expense of a machine shop to make new oversized bushings. -Outside diameter of a 3/4 ton bushing. -Inside diameter of a 3/4 ton bushing. -outside diameter of a 1/2 ton kingpin. Anybody have new ones laying around to measure?
| | | | | Joined: May 2015 Posts: 11,054 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 11,054 | On the bushings, the parts manual says 1-1/4 x 1 ID for the 3/4 ton, and for the 1/2 ton 1-5/16 x 1-5/64 (kind of hard to read on the 1/2 ton - may have been 1-3/16.) No sizes though on the king pins.
Kevin 1951 Chevy 3100 work truckFollow this saga in Project JournalPhotos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together. | | | | | Joined: Feb 2019 Posts: 4,476 AD Addict & Tinkerer | | AD Addict & Tinkerer Joined: Feb 2019 Posts: 4,476 | Oreilly’s Auto Parts lists the OD of the king pins as .866” for the 1/2 ton and .921” for the 3/4 ton. I know the listing for the 1/2 ton is correct as I just replaced mine. Can’t verify the 3/4 though. [ LINK]
Phil Moderator, The Engine Shop, Interiors and Project Journals1952 Chevrolet 3100, Three on the Tree, 4:11 torque tube Updated to: ‘59 235 w/hydraulic lifters, 12v w/alternator, HEI, PCV and Power front Disc BrakesProject JournalsStovebolt Gallery Forum | | | | | Joined: May 2015 Posts: 11,054 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 11,054 | Oreilly’s Auto Parts lists the OD of the king pins as .866” for the 1/2 ton and .921” for the 3/4 ton. I know the listing for the 1/2 ton is correct as I just replaced mine. Can’t verify the 3/4 though. [ LINK] Hmmm! That sure doesn’t match up with the bushing dimension I found. Way too much clearance.
Kevin 1951 Chevy 3100 work truckFollow this saga in Project JournalPhotos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together. | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | | | | | | Joined: Jan 2015 Posts: 51 'Bolter | | 'Bolter Joined: Jan 2015 Posts: 51 | Moog makes a .010 over kit. I’m not sure how worn the hole is. I also found some kits with the stock pin size with a .015 over or on the bushing. The kit was over $200 I dropped it at the machine shop today. They haven’t gotten back to me with a plan. He did mention some kind of spray welding may work but I was just talking to the counter man not the machinist. He did say he gets $100 to install the bushings and team and hone. I’ll keep you posted. Thanks | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | "I also found some kits with the stock pin size with a .015 over or on the bushing."
Moog? What is the part number? | | | | | Joined: Feb 2019 Posts: 4,476 AD Addict & Tinkerer | | AD Addict & Tinkerer Joined: Feb 2019 Posts: 4,476 | When I faced the same dilemma this past summer, I did some extensive searching on the web and the only oversize kits I found were for the king pin. I found both .010” and .015” kits. So if you straight axle was worn you can ream the axle out to the size of the oversized king pin.
I did not find any kits that contained oversized bushing that were meant to fix worn steering knuckles. I know from fellow Stovebolt’s that the kits were offered years ago but they seem to have vanished off of the market.
If you found one of these bushing kits, please let me and our fellow bolters know where and the part numbers and we would be very appreciative.
Phil Moderator, The Engine Shop, Interiors and Project Journals1952 Chevrolet 3100, Three on the Tree, 4:11 torque tube Updated to: ‘59 235 w/hydraulic lifters, 12v w/alternator, HEI, PCV and Power front Disc BrakesProject JournalsStovebolt Gallery Forum | | | | | Joined: Feb 2019 Posts: 4,476 AD Addict & Tinkerer | | AD Addict & Tinkerer Joined: Feb 2019 Posts: 4,476 | Thanks for the link to FCRC Machine. Your first link for Hagen’s Auto Parts appears to be for cars. I’m going to save that link (FCRC) in case my Loctite fix doesn’t hold up. Let us know how you made out with the machine shop repair and please do post the Moog part # if you can. That would be great!
Phil Moderator, The Engine Shop, Interiors and Project Journals1952 Chevrolet 3100, Three on the Tree, 4:11 torque tube Updated to: ‘59 235 w/hydraulic lifters, 12v w/alternator, HEI, PCV and Power front Disc BrakesProject JournalsStovebolt Gallery Forum | | | | | Joined: Jan 2015 Posts: 51 'Bolter | | 'Bolter Joined: Jan 2015 Posts: 51 | The machinist was able to weld up the one bushing and machine it to the correct size. The over size kit from Rare Parts #30348 used a stock diameter pin but the bushings came .015 over on the outside diameter. This would have worked but that kit was $230 on eBay and I still would have needed to bore all the spindle holes over size. The machine shop was able to weld up the one hole and bore it to spec. They pushed in all 4 bushings. The whole thing was $175. I was real happy the way it all worked out. It’s nice to have a good machine shop handy. If anybody wants the machine shop # drop me a line. Don | | |
