6 members (50 Black, greenie-reddy, 60steve, 52Carl, GradyB, cmayna), 133 guests, and 5 robots.
Topics128,204
Posts1,057,294
Members48,467
Here are some pictures of a new hydrovac unit from fleet-products.ca they are based out of Calgary, Alberta.
They have gotten away from the original type leather seal so one less thing to worry about.
This is for a 1955 Chev 2 ton (1600) Canadian model.
I didn't know these were being reproduced...nice to know. How does the cost of new vs rebuilt compare?
Mike B smile
Mike Boteler
1956 Chevy 3100 Resto Rod
1952 Willys M38 Army Jeep
1983 Jeep CJ7 Laredo
1984 Jeep CJ7
Silver Spring, MD
I've always been impressed by the construction of Hydrovac units- - - - -rugged, "no nonsense" pieces of equipment meant to last a long time and be repairable when necessary. They serve the same purpose as firewall mounted boosters- - - -"Make the driver's leg stronger"- - - - -but they do it better than less-robust equipment. Just looking at the diameter of the boost piston, and the stroke makes it appear that lots of brake fluid at a high pressure is available when needed. Some older motorhomes used two small hydrovacs with a split brake system, back in the 1970's. I believe they were plumbed in a "dual diagonal" configuration, where one rear wheel and the opposite front shared the same hydraulic system.
1 Offline
Ain't that purty. Looks just like the one I installed on my one-ton. Sent in a unit from an old Cadillac for a core. According to a book I have, 70+% of the braking force is done by the hydrovac. I installed mine after my knee gave out when driving my rig with slide-in camper pulling two motorcycles on a trailer through Vancouver rush-hour traffic on the way out to Vernon BC. It's the same knee that I use to kick-start the motorcycles. Could there be a connection?
1951 3800 1-ton
In the DITY Gallery
Mike B,
Sorry for the late reply, I would have to look back to check now what it cost me but I believe it was around 400 $ Canadian.
The cost of then new unit was fair considering what I would have had to pay to have a rebuild kit shipped to Canada from the States.. Especially when factoring in the possibility of receiving wrong parts etc.. If I would have sent it out for a rebuild, again it would have gone out to the states and it would have been a total mess around and the same price if not more once said and done.
Thanks for the update!
Mike B smile
Mike Boteler
1984 Jeep CJ7
Silver Spring, MD
