Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
0 members (), 135 guests, and 4 robots.
Topics128,275
Posts1,058,572
Members48,492
Here are some pictures of a new hydrovac unit from fleet-products.ca they are based out of Calgary, Alberta.
They have gotten away from the original type leather seal so one less thing to worry about.
This is for a 1955 Chev 2 ton (1600) Canadian model.
I didn't know these were being reproduced...nice to know. How does the cost of new vs rebuilt compare?
Mike B smile
Mike Boteler
1956 Chevy 3100 Resto Rod
1952 Willys M38 Army Jeep
1983 Jeep CJ7 Laredo
1984 Jeep CJ7
Silver Spring, MD
H Online: Content
I've always been impressed by the construction of Hydrovac units- - - - -rugged, "no nonsense" pieces of equipment meant to last a long time and be repairable when necessary. They serve the same purpose as firewall mounted boosters- - - -"Make the driver's leg stronger"- - - - -but they do it better than less-robust equipment. Just looking at the diameter of the boost piston, and the stroke makes it appear that lots of brake fluid at a high pressure is available when needed. Some older motorhomes used two small hydrovacs with a split brake system, back in the 1970's. I believe they were plumbed in a "dual diagonal" configuration, where one rear wheel and the opposite front shared the same hydraulic system.
1 Offline
Ain't that purty. Looks just like the one I installed on my one-ton. Sent in a unit from an old Cadillac for a core. According to a book I have, 70+% of the braking force is done by the hydrovac. I installed mine after my knee gave out when driving my rig with slide-in camper pulling two motorcycles on a trailer through Vancouver rush-hour traffic on the way out to Vernon BC. It's the same knee that I use to kick-start the motorcycles. Could there be a connection?
1951 3800 1-ton
In the DITY Gallery
Mike B,
Sorry for the late reply, I would have to look back to check now what it cost me but I believe it was around 400 $ Canadian.
The cost of then new unit was fair considering what I would have had to pay to have a rebuild kit shipped to Canada from the States.. Especially when factoring in the possibility of receiving wrong parts etc.. If I would have sent it out for a rebuild, again it would have gone out to the states and it would have been a total mess around and the same price if not more once said and done.
Thanks for the update!
Mike B smile
Mike Boteler
1984 Jeep CJ7
Silver Spring, MD
