| | | Forums66 Topics128,009 Posts1,055,295 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2018 Posts: 30 Olddog | | Olddog Joined: Oct 2018 Posts: 30 | Anyone know if a 48 GMC transmission 4-speed will mount to a 305 Chevrolet V8, On a 228 engine at the moment. Any and all help greatly appreciated. Yankabilly. | | | | | Joined: Jun 2011 Posts: 5,096 Crusing in the Passing Lane | | Crusing in the Passing Lane Joined: Jun 2011 Posts: 5,096 | Trans should be an SM-420, should bolt right up.
Ed
| | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 | The lower bolts may be a bit of an issue but using the correct technique, will solve. Novak says:
"While the Muncie 420 can be used with any GM engine having the "regular" GM transmission bolt pattern, this transmission installs more easily with the open bottom Chevrolet bellhousings because the lower holes in the transmission case are threaded rather than drilled for clearance. The threaded hole case cannot be modified, so the lower attaching bolts must be installed from inside the bellhousing.
This is minorly inconvenient on full circle (one piece) bellhousings such as Buick V6 and 1962 and newer Chevrolet V8. The lower bellhousing holes must be drilled for bolt clearance (17/32" drill) and the clutch release arm, bearing, and bellhousing must be assembled to the transmission and then assembled as a unit to the engine. While this may not be convenient, it is not difficult and the results are worthwhile.
When using later GM aluminum bellhousings with the SM420, note that the transmission top cover casting protrudes into the bellhousing rear face and machining for clearance may be necessary."
Right is right, even if everyone is against it, and wrong is wrong, even if everyone is for it. - William Penn | | | | | Joined: Oct 2018 Posts: 30 Olddog | | Olddog Joined: Oct 2018 Posts: 30 | Thank you for the information you have provided. Yankabilly. | | | | | Joined: Oct 2018 Posts: 30 Olddog | | Olddog Joined: Oct 2018 Posts: 30 | Thank you for the information. Yankabilly. | | |
