11 members (Jay R, wilbur53, Gdads51, TUTS 59, DaveV, RLB, WICruiser, Phak1, Otto Skorzeny, 55shaker, 1 invisible), 109 guests, and 4 robots.
Topics128,056
Posts1,055,789
#134588 06/29/2006 5:09 AM
does some one make a balancer like the factory style with the pulleys on the outside ring to fit the 250 inline motor that is better then the stock unit?
thanks yall
#134589 06/29/2006 6:18 PM
I have used a Fischer damper from Cliffords and also an ATI Super Damper. The ATI unit is for a small block Chevy and you machine about 1/4 of an inch off the "snout" so that it will fit closer to the timing cover but it works slick and I spin the motor hard. The ATI is nice because any small block Chev pulley will bolt right on. I used the one that fits flush against the damper. Good luck!
