7 members (Otto Skorzeny, 5 Window 9434, JW51, Gib70, mk72, Wally / Montana, Gray_Ghost), 85 guests, and 1 robot.
Topics128,053
Posts1,055,776
#134588 06/29/2006 5:09 AM
does some one make a balancer like the factory style with the pulleys on the outside ring to fit the 250 inline motor that is better then the stock unit?
thanks yall
#134589 06/29/2006 6:18 PM
I have used a Fischer damper from Cliffords and also an ATI Super Damper. The ATI unit is for a small block Chevy and you machine about 1/4 of an inch off the "snout" so that it will fit closer to the timing cover but it works slick and I spin the motor hard. The ATI is nice because any small block Chev pulley will bolt right on. I used the one that fits flush against the damper. Good luck!
