5 members (Joe H, HandyAndy, Gdads51, 3B, dt235sd), 122 guests, and 1 robot.
Topics128,049
Posts1,055,693
#134576 06/27/2006 7:29 AM
That's good, cause I picked up a 400 turbo, on the weekend but no torque converter came withit.I might put it into my 53 1/2 ton with the 350 motor eventually. hows your s10 adaption working out?
#134577 06/27/2006 2:04 PM
The TH400 is a very strong transmission.
My S10 swap is moving slow. I've been very busy with work. Target date is Sept 1.
Mostly need to sand & paint everything.
Mike
46 Chev One Ton Panel - S10 Frame Project
"What if the Hokey-Pokey is REALLY what it's all about?" - J. Buffet
#134578 06/27/2006 6:03 PM
That is one awesome and unusual looking panel,I think it's going to be great.I'm just totally building mine on a shoe string, it's just a 53 1/2 ton chev.I'm putting in a V8 auto with a 76 olds 442 rear end.I think I'm going to paint it metallic silver with the rally wheels.
#134579 06/27/2006 6:04 PM
#134580 06/29/2006 3:44 AM
KillerNight,
are you using an olds engine & trans?
Mike
#134581 06/29/2006 4:57 PM
no, they are Chev ,I did have an excellent 350/400 olds,with about 15,000 miles since a rebuild, shift kit ,etc,but I couldn't even get a phone call on them for $300,in a 77 el camino,turn key,so I pulled the swivels ,tilt,pw,pb,airshocks,pulse wipers,rally wheels and called the shreaders.I guess I live too far far the city.oh ,and the quick change rear end(I don't have to pull the rear cover to get the axles out)
