1 members (delky), 65 guests, and 2 robots.
Topics128,049
Posts1,055,740
#1345686 02/09/2020 11:26 AM
I'm trying to get my wheels off, but I was suprised that the wheel nut is counter clockwise, and that there is a double nut for the dually system.
So where do I find the square 13/16" tool to loosen these and what is it called?
You can use an eight point socket.
SimS
Search "Budd style lug nut wrench"
Lots more pictures
3B Offline
Hy Steve-W, You are working with Budd wheels which use an inner and outer nut system for the rear wheels. The left side of the vehicle as viewed while sitting on the seat is left hand thread for the wheel retaining hardware front and rear axles. As Paul_WNC has said, search for Budd wheel sockets or wrenches to help you when working with this wheel mounting system, good luck.
H Online: Content
NAPA sells a combination socket that works on both the inner and outer nuts. I've got one that fits my 3/4" drive impact wrench, and there's also a 1" drive type for the big commercial air wrenches. I've changed a bunch of those wheels with a big 4-way lug wrench and a 6 foot cheater pipe when I was doing maintenance for a very small trucking company. The boss was too cheap to buy air tools!
Try this one:
https://www.tooltopia.com/grey-pneu...cid=scbplpGRE3223C&sc_intid=GRE3223C
7
7 Offline
Grainger also has the socket.
Wow guys, thanks for the fast and helpful reply's. Keep you posted, because I live in the Netherlands, so have ship the tool
You might check with a truck tire shop, thought I'd seen the Budd type in Europe.
BC
1960 C60 pasture art
This is my first big truck, so I'm learning on the job. Thanks will check it out
So just to give the last update here to close the topic.
In january I ordered through Amazon and it got delivered a week later, so pretty good.
got the wheels off and the progress can be followed in my Ratification project page.
