3 members (j05h79, Phak1, Jay R), 73 guests, and 3 robots.
Topics128,154
Posts1,056,837
Members48,456
Hi All,
I upgraded my tie-rod and put new ends on my 48 1/2T. Should the tie-rod-end threads point down, putting the tie-rod higher, or should it come up from the bottom?
I almost feel like I shouldn't have to ask this question... smile
Steve
1948 1/2 Ton 6-volt 216
AD Addict & Tinkerer
My original steering arms have the ball pointIng up with the tie rod on top.
Phil
Project Journals
Stovebolt Gallery Forum
Thanks Phil, Initially I was going to install with the tie-rod being higher, and the ball threads pointing down (my left pic), but I had someone think it should come up from the bottom (not a stove-bolt guy). This is why I posted...thanks
If your modern design tie rod ends have tapered shanks, have you reamed the holes in the steering arms to match the taper? Putting a tapered shank in a straight hole isn't going to work at all.
One old-timer I knew who had apprenticed as a blacksmith before becoming an auto mechanic used to convert those steering arms by getting the end of the arm red hot with a rosebud torch and driving a big tapered punch into the hole. No, I wouldn't recommend trying that approach!
Jerry, The modern T/R ends are straight and not tapered.It fits good in the pressed hole.
Steve
The answer to your question is whether the tie rod installed on top will have enough clearance when the springs are compressed to the bump stops. Also if you're comfortable with the road clearance with the tie rod mounted below the steering arms. One consideration is whether in the extremely remote chance that the cotter pin comes out and the nut loosens up that gravity will make the tie rod fall off on the road. Mounted on top, gravity would work in your favor, on the bottom, not so much. (I did say extremely remote.)
As good as one that's pressed in and hot riveted? I don't think I'd want to bet my life on something like that if it's got even a little bit of a loose fit.
Jerry, I'm sure your correct. I was just asked a question about a tapper and answered. My original question was on orientation of application for others with experience using the new T/R ends...
Kevin - thanks. My thoughts on the top down direction was exactly the same thoughts you mentioned. I do have spring/bumper clearance too.
Steve
The threads should point down. The ball inside the new tie-rod will be above the steering arm just like the original ball stud
Thank You Fiddlerpin!!
