1 members (1 invisible),
65
0
Mod | | | Forums66 Topics128,049 Posts1,055,740 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2010 Posts: 56 GPK 1961 | | GPK 1961 Joined: Mar 2010 Posts: 56 | Good Morning -
I have 61' short step side c10. It has its original 235 and 4-speed manual transmission. My question is I need to remove the engine for a rebuild. When I did my 61' c20 with a 283 and Powerglide, I left the trans in place and just pulled the motor. What have you done? Is the best way to drop the transmission from the bell housing, then remove the engine? Driveway/garage set up for the work. Thanks - GPK1961
New project - 1961 Apache 10 Step-side
| | | | | Joined: Apr 2005 Posts: 2,097 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,097 | I would remove the transmission first. Fred
| | | | | Joined: Dec 2019 Posts: 117 'Bolter | | 'Bolter Joined: Dec 2019 Posts: 117 | I see no need to remove the tranny if you are going to remove the engine. The 4 spd trans has a bell-housing that is mounted to a cross member, therefore, it is well supported. Remove the starter, disconnect the engine from the bell-housing. You might have to remove the floor pan to gain access to the upper bolts on the bell-housing, however, a long extension and a universal drive socket might do the job. I would not suggest trying to remove the eng/trans as one unit. Wm. | | | | | Joined: Feb 2017 Posts: 83 Vintage Truck & Tractor | | Vintage Truck & Tractor Joined: Feb 2017 Posts: 83 | Dont waste your time trying to remove the engine without removing the tranny first.
Current project; 1961 C20, 235 I6
| | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 | If you have a removable tranny cross member, you may want take it out together. Provided you have the radiator and all that out of the way. It all depends on the cross member removal to get it to swing down and of course the shifter stick must be removed. It's nice if the whole front clip is off, of course. The all in one method is nice because that tranny is very heavy to handle from crawling under and will crush you. Getting the bell housing off motor can also be a pain. The 4 speed is cantilevered with major loss of support after bell housing is taken off motor. Bottom line is that removing both together is a viable option. With some advantages.
Right is right, even if everyone is against it, and wrong is wrong, even if everyone is for it. - William Penn | | | | | Joined: Mar 2010 Posts: 56 GPK 1961 | | GPK 1961 Joined: Mar 2010 Posts: 56 | Thanks for the advice! I'll post some pictures once I get started. GPK1961
| | | | | Joined: Oct 2015 Posts: 406 'Bolter | | 'Bolter Joined: Oct 2015 Posts: 406 | You have to remove the trans, clutch and fly wheel to unbolt the bell housing from the engine if its a 235.
good planning is no substitute for dumb luck
| | | | | Joined: Dec 2019 Posts: 117 'Bolter | | 'Bolter Joined: Dec 2019 Posts: 117 | I have removed several V-8's and 6 cyln engines from '63/68 4spd trucks without removing the trans/bell-housing. The rear portion of the trans does need to be supported because as I recall the only mount for the trans is the rear motor mount to the bell-housing. Guess I'll have to crawl under the '66 C10, six foot bed truck I have to refresh my memory. Wm. | | | | | Joined: Oct 2015 Posts: 406 'Bolter | | 'Bolter Joined: Oct 2015 Posts: 406 | 61 with 235 is a different animal compared to 63 and up . where they used 230- 292 and 283, all with the same bell housing , the v8 60 through 62 had the same housing but with hydraulic clutch. 235-261 housings bolt to the block from inside the housing no exterior bolts .
| | | | | Joined: Dec 2019 Posts: 117 'Bolter | | 'Bolter Joined: Dec 2019 Posts: 117 | Interesting, did not know the '62 and earlier were so much different. I know that the 235 style of engine was around from the early '40's until '62. I have a '40 1.5 ton 4x4 (ex military G506) and a '40 3/4 ton panel with the 235 and 4spd trans. Wm.
