| | | Forums66 Topics128,036 Posts1,055,454 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2014 Posts: 70 'Bolter | | 'Bolter Joined: Nov 2014 Posts: 70 | I am replacing the radiator support on my 66 C-10, should I paint it before I install it or is the paint on it from the manufacturer sufficient? My concern is there enough paint on it to prevent rust.
ESum
| | | | | Joined: Jul 2011 Posts: 785 'Bolter | | 'Bolter Joined: Jul 2011 Posts: 785 | Take a shop rag with some lacquer thinner on it and see if it will take off the factory paint.. If it comes off on the rag, I'd say you need something better to seal the support. | | | | | Joined: Jan 2017 Posts: 124 Shop Shark | | Shop Shark Joined: Jan 2017 Posts: 124 | I've never seen a panel like that come through with a finish coat on it. If it was me I'd scuff it up with some scotch brite or 320 paper, clean it good then hit with 1 or 2 coats of epoxy primer. Then paint it what ever color its supposed to be.
38 Chevy 1/2 ton being resto-moded 65 AC Cobra replica USAF vet
