4 members (Maybellene, 49choptop, Youngin' Tut 59, rfs56trk), 124 guests, and 3 robots.
Topics128,096
Posts1,056,477
Members48,444
Got a tip for you guys that are using the S-10 conversind on the AD trucks. The '99 and up S-10 has a 4-wheel disk brake option. You'll see it mostly on 4-door Blazers. The rear axle is a direct swap and you can get larger front brakes by just swapping the front spindle assembly. It's a bolt in-no balljoint change necessary. This will get you a thicker rotor and dual piston calipers. You will have to use the hub assemblies for the knuckle-the bearing is different.
Bill Burmeister
Ter Offline
Hi Longbox55
Sounds like a great tip.
Brakes are good,,, better brakes are 'real' good!
Ter
