| | | Forums66 Topics128,142 Posts1,056,476 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | Got a tip for you guys that are using the S-10 conversind on the AD trucks. The '99 and up S-10 has a 4-wheel disk brake option. You'll see it mostly on 4-door Blazers. The rear axle is a direct swap and you can get larger front brakes by just swapping the front spindle assembly. It's a bolt in-no balljoint change necessary. This will get you a thicker rotor and dual piston calipers. You will have to use the hub assemblies for the knuckle-the bearing is different.
Bill Burmeister | | | | | Joined: May 2002 Posts: 144 Shop Shark | | Shop Shark Joined: May 2002 Posts: 144 | Hi Longbox55 Sounds like a great tip. Brakes are good,,, better brakes are 'real' good! Thanks Ter | | |
