Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
3 members (Phak1, Hotrod Lincoln, DoubleB), 154 guests, and 4 robots.
Topics128,284
Posts1,058,526
Members48,490
I need to purchase new tires. Was wondering if 15x8 wheels and 255/70R15 tires will fit on the truck alright. It's original height. I want tires the tires to look a little beefier than the way the originals sit.
"The greatest use of life is to spend it on something that will outlast it" ~ William James
'25 Chevy Superior
'66 Chevy C10
'03 Chevy Silverado 1500 HD
For overall looks and handling I prefer 15 x 7 with 235/75R15. The 15 x 8 wheels might interfere with the suspension and the 70 series tires might alter your overall gear ratio, lowing it.
Since you posted your question in the '60-66 topic I would assume that your truck falls within that year range, therefore it most likely does not have power steering and gearing that would be normal for 670 x 15 tires, which are in the 28" range, very close to the 235/75R15 tires.
I have 235/75R15 on 5 lug alloy wheels on 3.42 10 bolt GM rear end in my '64 C10, trk drives great. Wm.
1964 C10 with Railroad cab
60-66 Forum
1940 Chevy G506 4x4
Big Bolts
1937 GMC T14
Project Journal
