6 members (homer52, UtahYork, HelmutVonSchet, wilbur53, klhansen, Rich'sToys), 162 guests, and 0 robots.
Topics128,113
Posts1,056,616
Members48,450
Hi all, looking for distance between clutch surface and pressure plate surface before resurfacing step flywheel.
1937 1 1/2 ton 10" clutch 9 bolt pressure plate
Fly wheel numbers 838174. Gm8. C51 (or C51)
Guessing dimension is around 1.187 but not sure.
Thanks, John
37 Chevy 1.5 ton
17 Dodge Brothers Roadster
23 Dodge Brothers Touring
23 Dodge Brothers Coupe
73 Plymouth Scamp 2 dr
I'm not sure you will be able to find a dimension for the stand surface. Tried to find it on a Cat flywheel a few years ago and were unable to find a spec. for it any where. ended up measuring another fly wheel. I believe the usual method is to measure the height before starting, and / or remove exactly the same amount from both surfaces.
1949 3100
While buying clutch disc from local clutch rebuilder he confirmed measurement of 1.187.
37 Chevy 1.5 ton
