| | | Forums66 Topics128,082 Posts1,055,964 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2016 Posts: 253 'Bolter | | 'Bolter Joined: May 2016 Posts: 253 | I found some info online for a driveshaft from a 1969 c50 and the length is 44" which is what I need. They listed the vin CE539J808465 and i was wondering if someone can decode vin to find out what engine/trans/rear end was in it?
I'm not planning on buying this exact one cuz their asking 200bucks plus shipping lol but it gives me hope that I could find one on a truck at my somewhat local boneyard of the exact length. | | | | | Joined: Sep 2011 Posts: 1,453 'Bolter | | 'Bolter Joined: Sep 2011 Posts: 1,453 | E = 8 cyl, S = 6cyl in these years, doesn't tell specific engine.
BC 1960 Chevy C10 driver 261 T5 4.10 dana 44 power loc 1949 GMC 250 project in waiting 1960 C60 pasture art Retired GM dealer tech. 1980 - 2022 | | | | | Joined: Mar 2004 Posts: 6,214 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 6,214 | The easiest and cheapest thing you can do is to measure from Trans U-joint to Rear U-joint (centers) and take your drive shaft to your local big truck suspension shop and have them shorten and balance it. The last one I had done cost about $80...way better than buying something with unknown history and you know both of your U-joints match your trans and rear yokes. While there have then press on new U-joints. Mike B  | | | | | Joined: Oct 2019 Posts: 15 No Longer a Big Bolt Owner | | No Longer a Big Bolt Owner Joined: Oct 2019 Posts: 15 |
I usually answer to Todd ---------------------------------- Daily Drivers: 2005 Chevrolet Silverado 3500 DRW 6.6L LLY/Allison 5 Speed 1989 GMC C7000 TopKick Pickup 3208T Caterpillar/Eaton-Fuller 6 Speed
Project Truck (SOLD): 1969 C50 Farm Truck 292c.i. w/SM465 tranny and 2-speed rear
| | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 | Looks like 67-71 at least. No info on trans or diff. You should probably focus on C50 WB to get the correct length. WikiLeaks says: 125", 137" 149" 167" 189" 203". The tandem C50's possibly had three more WB's. Click
Right is right, even if everyone is against it, and wrong is wrong, even if everyone is for it. - William Penn | | |
