4 members (Biermann, ndkid275, Wayne67vert, Peggy M), 168 guests, and 4 robots.
Topics128,164
Posts1,056,965
Members48,458
Appreciate you all who took a little time to read my post.
Finally getting the 1949 Chevy 3/4 ton truck looking a little better. Sprucing up the interior led me to install a new headliner. Only after trying to install it did I realize putting it in wasn't as straight forward as it seemed.
I understand the 1949 Chevy truck came in two variations; the early 1949 models and the later 1949 models. I am pretty sure mine is the early model 1949 as the headliner center bow is screwed to roof of cab instead of the "floating type" .
I am real sure I specified this when I order the headliner but now I am not sure which truck I have.
The rear piece was a pretty easy to figure out but the front piece I am a little perplexed about how it would be supported in the center.
Also, the two headliner pieces I have are both too big in depth. I think if I were to trim them back they would fit but trim back by how much? The original headliner is long gone so no template. Any ideas of the size I would need to trim these down to? An installation video, wedsite or a diagram would be really helpful or just some old fashion advice on what to do would be great to. Any help would be greatly appreciated. Thanks!
https://www.stovebolt.com/ubbthread...nstallation-sequence-48.html#Post1147110
This should answer your questions or at least get you started.
What style is this? Early 49?
That was in use from 1947 until remaining stocks were consumed in early to mid-1949. This was replaced by the floating “S” bow in use through 1st Series 1955 models.
Far be it from me to challenge the honorable Mr. Allen, but I zoomed in on your pic and I do not see any screw holes in the metal at the top of the door opening for the early '49 metal windlace retainer.
I am thinking that you have a late '49, and the original c-channel windlace retainer has been removed. Someone may have screwed the early center headliner support on to a later cab.
2 cents.
That bow is spot welded in place as per original not screwed in, can you confirm that Barnfind? I cannot see enough of the windlace to comment on that.
I will confirm when i get home but i do believe its spot welded in. As for the windlace that was something i was also gonna ask for help on because I honestly don’t understand it. I see people speak of it all the time but mine looks like theres no way to attach. Only channel i see is over top of the door where it looks like the headliner sits in??
*****didnt mean to change subjects on the thread but i just posted my pic to try and learn/identify the early/late headliner theme because i too will be doing this soon.
These are the only pics i have saved of that area.
Barnfind, look for evidence of old spotwelds on the inside perimeter of the door opening where the old windlace c-channel used to be. You should see 1/8th inch dimples in the metal, spaced somewhere around 2-4 inches apart. If you find them, then your truck would have come with the floating center headliner bow.
A couple interesting things in your picture. Serial number plate is Canadian? It would answer some questions if decoded. Your DS cowl vent has the early '49 plate with the lock which was replaced in mid-year with a straight version, does it have springs?
https://www.flickr.com/photos/advance-design_parts_co/12647382934/in/album-72157641244124604/
I believe it does have springs. This is the plate.
According to this http://www.oldgmctrucks.com/page0015.html you have a 1949 that falls near mid-year (13,531 FC-152 models produced). Nobody but the factory is going to spot weld that bracket where it is (TBC). I have no idea why you do not have the channels or weatherstrip assemblies other than a lot can happen in 71 years.
One way to confirm earlier weatherstrip is to look for these holes on both sides of the dash for screw removal.
https://www.flickr.com/photos/advance-design_parts_co/49456568082/in/album-72157631868452754/
Thats NOT a canadian tag though right?
When I first saw it I could not tell but no it is not Canadian as far as I know?
Ok.....im gonna make a new thread about the windlace confusion but back to the original topic of the headliner. Mine would be considered the “early style screw in bow” type correct?
That is my conclusion, that requires the earlier cardboard set for a correct install (1947-early ‘49) is how most vendors advertise it.
Moderated by  ndkid275, Phak1
