7 members (TooMany2count, 55shaker, klhansen, Phak1, 3800GUY, Gdads51, 1 invisible),
75
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,138 Posts1,056,440 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2003 Posts: 25 Junior Member | | Junior Member Joined: Apr 2003 Posts: 25 | Whats the best clip of front end to fit these trucks? A freind pickep one up and for what we can tell the track width with the 80's Gm truck front end is too wide, any help would be greatly appreciated. thanks | | | | | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 | Well the first question to ask when some one asks what the best is, is best for what?
There are lots of options and which is best for your friend may not be what someone else thought best. How are you going to use this truck? What's your fabrication skill level? What are you trying to accomplish with a clip?
Camaro, Chevelle, G-Body, Mustang II, '63 to '87 GM pickup, Corvair van. Those are the ones I've seen, and there are reasons to consider or reject each.
1955 1st GMC Suburban | 1954 GMC 250 trailer puller project | 1954 GMC 250 Hydra-Matic | 1954 Chevy 3100 . 1947 Chevy COE | and more... It's true. I really don't do anything but browse the Internet looking for trouble... | | | | | Joined: Jun 2005 Posts: 887 Shop Shark | | Shop Shark Joined: Jun 2005 Posts: 887 | OldSub is right- there are lots of good clips- The easiest to install and service in the future is probably the mustang II, whether you cut it out of a donor car or buy one after market, those things, and parts for them, are as ubiquitous as volkswagen beatles in the 70s.
| | | | | Joined: Jul 2005 Posts: 2,031 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 2,031 | these guys are correct check ride height, ride, lowered, ease of operation, fit, cost, do you live on a dirt or paved road, hanger queen or driver, new or used bolt in ..... probably not @ least i have not seen one yet. then there's a rack and pinion w/ straight axle http://www.stovebolt.com/bboard/cgi-bin//ultimatebb.cgi?ubb=get_topic;f=22;t=005089#000000 then there's 5 link front suspension http://buzztrader.com/forum/pages/Old_Trucks/1139869292-100.html do a search for mustang II http://www.stovebolt.com/bboard/cgi...amp;record=2453879-184509-339T&dex=4
Jim & Caroline The highway is for gamblers, better use your good sense." Gooday-that's my 1¢ answer due to the lousy economy ~ cause I ain't got - no . mo . doe Every Shaver | Now Can Snore | Six More Minutes | Than Before ... | Half A Pound for Half a Dollar | Spread On Thin | Above the Collar || BURMA-SHAVE
| | | | | Joined: May 2006 Posts: 1 Junior Member | | Junior Member Joined: May 2006 Posts: 1 | Just FYI, there is a '52 Chevy featured in the June 2006 issue of Classic Trucks magazine. The owner used a front clip from a '70 Nova and also used the brakes and power steering from the same. | | | | | Joined: Jul 2003 Posts: 31 Junior Member | | Junior Member Joined: Jul 2003 Posts: 31 | There is a "bolt on " IFS kit available from RBS. I have never heard of anyone who has tried this, but if your not into welding and can put out the bucks, you might want to try it. Bolt on IFS kit from RBS | | | | | Joined: Apr 2003 Posts: 25 Junior Member | | Junior Member Joined: Apr 2003 Posts: 25 | Thanks alot for the info Guys. Looks like we are going with an s-10 frame. just have to shorten the frame one inch. | | | | | Joined: Jan 2005 Posts: 164 Shop Shark | | Shop Shark Joined: Jan 2005 Posts: 164 | Do you really need to shorten the frame? From what I've read, the regular cab long bed S-10 is an inch longer....but that centers the wheels in the back wheelwells better than the factory frame.
And for those of you doing a Mustang II.....they all look very flimsy to me. Are they holding up okay? | | | | | Joined: Dec 2003 Posts: 299 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2003 Posts: 299 | Yes, I wonder about that too, I've had 3 mustang II's and all of them rusted out right in the front frame, After owning them ,I would never want to use those myself. | | | | | Joined: Aug 2001 Posts: 154 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2001 Posts: 154 | Added a TCI M-II tubular arm to mine couple years ago, I did take off the 2" drop spindles and put on standard spindles,(my preference) but the ride is great, it has power rack and pinion. http://community.webshots.com/user/zeker6 see it here, Zeke
The Amish Connection 51 Chevy 1/2 ton 5 window,Vortec hotrod, no horse
| | | | | Joined: Feb 2001 Posts: 4,095 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 4,095 | bosher, i have a pacer IFS and it works well and i have had it for 20 yrs but if i were to do it over i would go with the mustang especially the rb"s unit, it looks great. ron
Ron, The Computer Greek I love therefore I am.1954 3100 Chevy truckIn the Gallery 2017 Buick Encore See more pix1960 MGA Roadster Sold 7/18/2017
| | | | | Joined: Jan 2001 Posts: 662 Shop Shark | | Shop Shark Joined: Jan 2001 Posts: 662 | Progressive Automotive ( http://www.progressiveautomotive.com) MII, 3-1/2 years, 33000 miles as a 4 season (salt too!) daily driver. No troubles at all. | | | | | Joined: Nov 2000 Posts: 1,969 'Bolter | | 'Bolter Joined: Nov 2000 Posts: 1,969 | I've read of Volare/Aspen transplants in addition to those listed. I agree that it depends on the use of the truck and what you want to do. Some suspension swaps will be too light to hope to haul anything again.
Professional Novice
