1 members (1 invisible), 103 guests, and 0 robots.
Topics128,117
Posts1,056,298
Members48,439
OK...so I pick up this '56 3600 with what appears to be a Pontiac 347 V8 (thanks Luke). It runs but a little rough and is very cold blooded. I thought I'd start by checking the spark plugs. WT*?? They don't have a traditional electrode and are imprinted with "Leonards Oil Firing" on the insulator. What's up with that? Do they cross to a more modern plug?
Scott
1964 GMC 1002 Long Wideside w/305E V6 & sm420 "Blue Jeans"
1996 Harley Davidson FLHTCI
1981 Husky 250CR
http://community.webshots.com/user/gmc1002hf5669a
The "fires in oil plugs" were used in worn oil burning engines that would foul normal plugs.Must be a reason for those plugs, huh? Perhaps the previous engine tuner installed those plugs because they were within arm's reach.At any rate just cross over to normal Pontiac 347 plugs, J-11 for Champion.
Champion!!!! eek those are for lawnmowers!!! :p
Thanks Tony. Let's hope they are in there because they were within arm's reach.
Scott
1981 Husky 250CR
Well, according to NAPA, Autolite 86 is the plug for the 347. I was able to replace the right side before it started to snow tonight. When I pulled the "oil firing" plugs, they just looked sooty, not oily.
Scott
1981 Husky 250CR
k10 Offline
Autolites! Those are for FQrds
Quote
That was ages ago. Autolite/Motorcraft split and Autolite is now part of the Honneywell group with Prestone and Fram, the makers of junk oil filters. I can't recall the exact date, but I think the split was in the 70's. Autolite did make the best plugs on the market when they were owned by Fored, but not anymore. Myself, I've been buying AC/Delco and have had no problems.
I had a 74 pickup with the 250 that was a plug killer, they wouldn't burn up or foul, but the ceramic would break down and cross-fire internally. Champions would last 3,000 miles, AC about 5,000 but Autolites would go for 7,000 to 8,000 miles.
Fred
52 3600
69 C-10
So Fred, who's oil filters do you like? I have used Frams for years and have heard good/bad about them. Some swear by them, and some swear at them.
Check here for some good info on oil filters. After reading this I'll not be using Fram anytime soon. I'm currently using AC/Delco with no problems.
72 Sierra Grande - Maych
Forget about "do it right the first time". Do it wrong the first time to learn how, then do it right the second time.
