6 members (Toadwart, FishinToms53, UtahYork, Southerntruck, homer52, 1 invisible), 160 guests, and 2 robots.
Topics128,087
Posts1,055,999
Members48,430
#1343510 01/25/2020 1:01 AM
Are the chrome front and rear bumpers identical/ interchangeable? How can I tell the difference if there is one?
*UNDER CONSTRUCTION*
1953 Chevrolet 3100 1/2 ton-previously abandoned resto.
My Project Bolt
I hate when people leave their brains at home. Seriously when did critical thinking and customer service go out the window? How about common sense and striving to go the extra mile? Idiots, surrounded by idiots it tell you.
1953 1/2 ton?
Front and rear bumpers were different.
The front bumper has more of a curve to it.
There should be some photos here?
I have been told that a front bumper will bolt on to the rear bumper brackets. In fact I bought a setup (rear brackets and front bumper) like that on my road trip. Check back with me next year (or later frown ) to see how that goes.
8
8 Offline
Don't forget that '51 was the first year that pickups came from the factory without a rear bumper.
-Tim
'51 Chevy 3104 w/'56 235, 848 Head, HEI Dizzy, Corvette Cam, Split Manifold and Dual Carter YF's
I have a front bumper on the rear of my 54 but it is different lots of spring to get it to bolt to the brackets .I am planning to get the proper one one of theses days.
1954 Canadian GMC 9300
"The Journey"
Follow in the DITY
Definitely different on pickups. Rear bumper is very flat and just curve in slightly on the ends. Front has more of a arc to it with curled in ends. I believe the panel trucks used the same front bumper also in the rear. Its hard to tell looking at them sometimes but they are actually very different when bolted on. I dont see you being able to get it on the truck if its the wrong bumper. The thing is like a big leaf spring and it just wants to stay where its at when you try flexing it.
Heres my 150 for reference. I could never find good pics online to really see the shapes so hope this helps you.
My '52 came with two front bumpers, one in back. I took off a few bolts (they were very difficult to turn).
When I got the second bolt out, I thought the bumper was going to cut me in half when it let go.
So yes, it is possible to put a front bumper on the back. Recommendable? Not so much.
This is my front bumper on the rear looks okay but as barnfind said it is like a leaf spring and it is loaded up to fit on the rear
"The Journey"
Follow in the DITY
I think that bumper will hit the license plate too. And kevinski its funny you say that because I unbolted mine from a truck stacked up on another truck and it was in a pile of trucks and it was a little twisted. I took the bumper bolts off with my Milwaukee impact gun. Well i was holding my hand on the head to keep it engaged so it wouldn’t spin in the square. Well when i got to that last corner one it let go like a bomb. I thought i lost some fingers or at least broke them. They were still there but they hurt for a while. Be careful with those bumpers under pressure.
Fox Offline
I’m not sure if this is original as well, but my AD 1 ton front bumper is considerly heavier built than the 1/2 ton’s. Same curve and dimensions, just thicker.
1970 Chevrolet C10
1950 Chevrolet 1-Ton Dually
"Ole Red Girl"
More pictures here
Parts trucks-
More info with good discussion on thickness and mounting. I purchased a 1-ton 52 a few years back and used the bumper for this wall mount, it is the nearly 1/4" thick as described in the attached.
https://www.stovebolt.com/ubbthreads/ubbthreads.php/topics/1276231/all/1-ton-pickup-rear-bumper.html
https://www.flickr.com/photos/advance-design_parts_co/15686100982/in/album-72157631866985745/
