7 members (Hotrod Lincoln, 46 Texaco, tclederman, papas52, dt235sd, MNSmith, 55shaker),
133
0
Mod | | | Forums66 Topics128,162 Posts1,056,913 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2017 Posts: 299 'Bolter | | 'Bolter Joined: Mar 2017 Posts: 299 | I'm in the process of putting my engine back together. I just got it back from the machine shop. My friend wants to know how to adjust the solid lifters in a newly rebuilt engine.
Thanks Steve Elmo | | | | | Joined: Feb 2004 Posts: 29,852 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,852 | Adjust the valve lash to .002" over the "hot" specification during assembly. There will be a little noise during the initial run-in, but the valves won't tighten up and possibly burn. After 20-30 minutes' cam break-in time, shut down and use the companion cylinder method of valve adjustment to tweak the clearance. It should be pretty close. I've done that with several hundred new engines. Jerry
| | | | | Joined: Dec 2008 Posts: 1,922 'Bolter | | 'Bolter Joined: Dec 2008 Posts: 1,922 | If you have good understanding of the 4-stroke cycle, you don't need a method. Just do one cylinder at a time. The methods save some steps and engine rotations, but all result in the same condition. | | |
