1 members (Hotrod Lincoln), 41 guests, and 0 robots.
Topics128,035
Posts1,055,560
#1343184 01/22/2020 2:46 AM
Is this a 47-53 cab with a 54;55 first series windshield?
1954 Canadian GMC 9300
"The Journey"
Follow in the DITY
KEVINSKI #1343188 01/22/2020 3:26 AM
What does the dash look like? The point at the top of the cab rules out '54-55.1
KEVINSKI #1343194 01/22/2020 4:19 AM
I seen this last month on the web and took a picture of the roof it was a Chevy with the early grill . I can’t find it on the web anymore but it was for sale in a showroom setting .
"The Journey"
Follow in the DITY
KEVINSKI #1343196 01/22/2020 4:43 AM
Found it at autabuy.com it is a 53 chev still don’t understand the window maybe just because it is reflection and don’t see the divider.
"The Journey"
Follow in the DITY
KEVINSKI #1343211 01/22/2020 1:22 PM
AD Addict & Tinkerer
It may be one of those custom one piece windows that were bent in the center to eliminate the center support. I’ve seen it before on some really high end customs.
Phil
Project Journals
Stovebolt Gallery Forum
KEVINSKI #1343218 01/22/2020 2:23 PM
Chevys of the 40’s has them for sale. Not cheap though!
One Piece V Bent Windshield
Phil
Project Journals
KEVINSKI #1343219 01/22/2020 2:30 PM
Phil's link has this: "Note: Both vehicle and glass will need modification to install."
KEVINSKI #1343224 01/22/2020 2:55 PM
I saw that too. I wonder what needs to be modified. I wonder if there’s a place you can get one that just fit’s.
In truth, I like the split windshield. It’s part of my ‘52’s character and I would never change it.
Phil
Project Journals
KEVINSKI #1343226 01/22/2020 3:17 PM
I found another on Brother’s website that doesn‘t have that warning.
One Piece Windshield
Phil
Project Journals
KEVINSKI #1343227 01/22/2020 3:31 PM
I like the divider bar also but my truck is a 54 has the one piece window ,for Christmas I found the outer stainless for the doors so when I seen this I thought maybe the stainless for the windows are the same except for were it joins at the divider .thinking that if they were the same shape they may work on a 54 with a piece of stainless to join it were the divider hides the join on the two piece window
"The Journey"
Follow in the DITY
KEVINSKI #1343278 01/22/2020 11:31 PM
I wouldn’t think they are the same shape. The ‘53 and earlier have completely flat windshields and I think your ‘54 is curved all the way thru.
I like the way the stainless trim looks too. It might be in my truck’s future too.
Phil
Project Journals
KEVINSKI #1343894 01/27/2020 5:12 PM
8
8 Offline
My understanding is that the 54 & 55 cab was redesigned to remove the peak, thus enabling the use of a single, flat piece of glass for the windshield.
As far as modifying the 47-53 cab for a one piece windshield, the bare minimum would be cutting out the divider bar. I'm not sure if anything else would be necessary.
-Tim
'51 Chevy 3104 w/'56 235, 848 Head, HEI Dizzy, Corvette Cam, Split Manifold and Dual Carter YF's
KEVINSKI #1343964 01/28/2020 3:16 AM
The pinchweld perimeter would need to be be massaged to match the curve of the '54-'55 glass.
KEVINSKI #1344014 01/28/2020 5:21 PM
I cant think of anything worse than having a pinchweld massage.
1946 GMC Project
"Back-in-the-day Restore"
KEVINSKI #1344166 01/29/2020 5:19 PM
We have done several and the only thing we do is remove the center divider bar and smooth up with a disc grinder/Dremel tool. Much prefer using a 53 style front clip on a 54 cab. No leaks or wind noise if a Steele gasket is used. Truck is a 1948 3100.
Shot from this angle best shows bend in glass
[img]https://i.postimg.cc/vgnb8JKV/one-piece-windshield-001.jpg[/img]
Straight on view from the outside:
[img]https://i.postimg.cc/hhpcD1yM/one-piece-windshield-002.jpg[/img]
Looking at an angle from the inside---some distortion:
[img]https://i.postimg.cc/LYFLspXd/one-piece-windshield-003.jpg[/img]
Straight ahead view from the inside---no distortion:
[img]https://i.postimg.cc/Z0TjP8TG/one-piece-windshield-004.jpg[/img]
Evan
KEVINSKI #1344897 02/04/2020 1:56 AM
probably just a one piece windshield kit starting to see a lot on vintage cars, my first on a truck, but why not?
Larry
Old man᠁Old truck᠁neither one goes very fast. All you need in life is TIME, PATIENCE and MONEY.
If you are missing one component, you'll need an abundance of the others two.
