| | | Forums66 Topics128,141 Posts1,056,488 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2019 Posts: 8 New Guy | | New Guy Joined: Sep 2019 Posts: 8 | Now that I have gotten my truck running, I need to figure out how to get her to stop!
Been doing some reading on the forums here about the hydrovac and brake cylinder rebuilding, however I still have a couple questions if anyone happens to know.
First: is there a supplier out there that has complete front wheel cylinders available for these big bolts? I was able to find rear but not front. (Have not pulled anything apart yet so dont know how pitted my wheel cylinders are they may be salvageable. Just curious worst case scenario)
Two: are the 1 ton master cylinders the same as the regular pickup trucks or are they specific to the larger trucks?
Three: this one is region specific, anyone near Chattanooga have a preferred parts supplier that knows a little bit more about these machines beyond Oreillys etc?
Appreciate any intel you guys might have!
'55 Chevrolet Grainer '57 Chevrolet 210
| | | | | Joined: Dec 2015 Posts: 2,063 Big Bolt Forum Moderator | | Big Bolt Forum Moderator Joined: Dec 2015 Posts: 2,063 | hopefully it was just a type above but Your 6400 is a 2 ton, not a 1 ton and no, the master cylinder is not the same as a 1/2 ton pickup. Napa and Rock Auto should both have rebuild kits for the front wheel cylinders and the master cylinder. I am not sure about the whole cylinder. Browse or search the big bolt forum though, there was a thread on this exact topic that came within the last week or so. Also, do you have a 55.1 or 55.2 (AD or Taskforce truck). They made a model change mid-year in 55. | | | | | Joined: Feb 2016 Posts: 1,990 'Bolter | | 'Bolter Joined: Feb 2016 Posts: 1,990 | You won't find an exact match for the front wheel cylinders, as 69Cuda noted read some of the posts in the Big Bolt forum. The casting number on the wheel cylinder will dictate which rebuild kit to use. The master cylinder is not the same as the 1/2 - 3/4 ton as 69Cuda wrote.
| | | | | Joined: Sep 2019 Posts: 8 New Guy | | New Guy Joined: Sep 2019 Posts: 8 | My truck is a 55.2, Task Force rig. Also yes "1 ton" was a typo, been using the phone and didn't catch that. I did re-read the post you guys mentioned. The first time around I did not catch where someone talked about the front cylinders being discontinued. Will start to pull some stuff apart and see what my casting numbers are.
| | | | | Joined: Mar 2004 Posts: 6,214 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 6,214 | Even it your wheel cylinders are pitted real bad they can be sleeved with brass or SS and be made better than new, so don't scrap your old stuff. Do a google search for wheel cylinder sleeving...I know White Post Restorations does it, but there may be others as well. Mike B  | | |
