7 members (walter74, Sjm, Jman, baldeagle, SmalltownTRKGuy, moparguy, 1 invisible), 343 guests, and 5 robots.
Topics128,166
Posts1,057,092
Members48,463
Hi . My buddy has a 2 ton 53 with a sm420 trans. and an open drive shaft. I have a sm420 set up for a torque tube. Can we change the rear bearing retainer and use my trans as a replacement? His has a parking drum on the rear of the box. Are the output splines the same? Will the PTO bolt up? I guess i'll find out when it gets warm enough to pull his out. His won't stay in 2nd gear . Thanks, Chip
Crusing in the Passing Lane
Novak has 420 rebuild kits.
Ed
Yes, everything ahead of the bearing retainer is the same. I got involved in the conversion recently, but the other way- - - -changing an open driveline 420 to torque tube drive. Do not discard the front universal joint yoke used with the torque tube- - - -it's unique to the 420 transmission, and it's very scarce! The joint cross and the rear yoke are the same as a 1/2 ton, but not the front!
Good info to pass on Jerry, I might add that if he plans to retain the parking drum and related appurtenances, of his bigbolt he will need the top loader off the original transmission unless the donor trans has the shaft for the brake handle. I have never seen a fine spline sm420 but a couple late models have them.Also even the sm420s found in 1/2 ton had a side cover pto provision that is identical. Basically sm420 from 1/2 tons on up to 2 tons are identical sans the rear bearing cover and ujoint for the enclosed driveshaft, and top cover for the hand brake.
Like Jerry says save the yoke and bell type rear bearing cover found in 1/2 and 3/4 ton trucks pre 55, getting hard to find.
1953 Chevrolet 3100
In the DITY Gallery
Video of the 261 running
1964 GMC 1000
Thanks for the replies. I'll keep you posted when we get into it . Baby it's cold outside! Snowing in Maryland
7
7 Offline
It got cold here for a couple of days, eight inches last night now raining, too sloppy to get the truck out of the barn.
