2 members (Hush, Forty9),
90
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,050 Posts1,055,643 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2016 Posts: 268 'Bolter | | 'Bolter Joined: May 2016 Posts: 268 | 49 gmc 1-ton. Hello. I have to resize the hole on the pitman arm. Can anyone tell me if the arm is cast iron or is it a forged steel? Like to know before any welding. Thank you 1949 gmc 1-ton | | | | | Joined: Feb 2004 Posts: 29,767 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,767 | It's forged, but welding on any kind of steering component can be deadly dangerous. What, exactly, are you trying to accomplish? Jerry
| | | | | Joined: May 2016 Posts: 268 'Bolter | | 'Bolter Joined: May 2016 Posts: 268 | I was going to do the adjustable draglink/steering arm upgrade and after removing the ball stud from pitman arm the existing hole is larger than the tie rod tapered end. 1949 gmc 1-ton | | | | | Joined: May 2016 Posts: 268 'Bolter | | 'Bolter Joined: May 2016 Posts: 268 | Was hoping I could weld/fill hole. Then drill and taper to correct size 1949 gmc 1-ton | | | | | Joined: May 2015 Posts: 11,028 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 11,028 | Maybe you can find a tapered bushing of the correct size. Put that in the hole, then the tie-rod end. Or get a matching tie-rod end. Like Jerry said, welding is not a good idea.
Kevin 1951 Chevy 3100 work truckFollow this saga in Project JournalPhotos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together. | | | | | Joined: Jun 2011 Posts: 5,096 Crusing in the Passing Lane | | Crusing in the Passing Lane Joined: Jun 2011 Posts: 5,096 | There is some 4wd accessory place that makes tapered bushings, name starts with B, look around, should be able to find them.
Ed
| | | | | Joined: Feb 2004 Posts: 29,767 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,767 | I'd suggest finding a tie rod with the proper taper and turning and rethreading the shank to match the turnbuckle sleeve you have. It would be much safer than welding on the Pitman arm. PM me if you want to explore that possibility a little further. I can probably do the threading. Jerry
| | | | | Joined: May 2016 Posts: 268 'Bolter | | 'Bolter Joined: May 2016 Posts: 268 | Yes I'll do some more searching. I am using the part #s that they listed in the tech tips. back to the drawing board. Thank you guys one and all. And Jerry yes I'll let you know. Thanks 1949 gmc 1-ton | | | | | Joined: May 2016 Posts: 268 'Bolter | | 'Bolter Joined: May 2016 Posts: 268 | I'll also make sure the little lady does the 1st test drive!!!! 1949 gmc 1-ton | | | | | Joined: Jul 2013 Posts: 5 New Guy | | New Guy Joined: Jul 2013 Posts: 5 |
1951 Chevy 292 Project
| | | | | Joined: May 2016 Posts: 268 'Bolter | | 'Bolter Joined: May 2016 Posts: 268 | Thanks. Got a couple ordered. Hope they fit. Thanks again 1949 gmc 1-ton | | | | | Joined: May 2016 Posts: 268 'Bolter | | 'Bolter Joined: May 2016 Posts: 268 | Thanks for the info. Exactly the problem I'm having. Good info on your other post 1949 gmc 1-ton | | |
