4 members (49nut, Steelonsteel, klhansen, Shardean), 73 guests, and 4 robots.
Topics128,022
Posts1,055,376
Members48,420
#1342467 01/16/2020 6:40 PM
49 gmc 1-ton. Hello. I have to resize the hole on the pitman arm. Can anyone tell me if the arm is cast iron or is it a forged steel? Like to know before any welding. Thank you
1949 gmc 1-ton
Johnny N #1342468 01/16/2020 6:43 PM
It's forged, but welding on any kind of steering component can be deadly dangerous. What, exactly, are you trying to accomplish?
Johnny N #1342469 01/16/2020 6:49 PM
I was going to do the adjustable draglink/steering arm upgrade and after removing the ball stud from pitman arm the existing hole is larger than the tie rod tapered end.
1949 gmc 1-ton
Johnny N #1342471 01/16/2020 6:53 PM
Was hoping I could weld/fill hole. Then drill and taper to correct size
1949 gmc 1-ton
Johnny N #1342481 01/16/2020 8:34 PM
Maybe you can find a tapered bushing of the correct size. Put that in the hole, then the tie-rod end. Or get a matching tie-rod end.
Like Jerry said, welding is not a good idea.
Johnny N #1342484 01/16/2020 8:59 PM
Crusing in the Passing Lane
There is some 4wd accessory place that makes tapered bushings, name starts with B, look around, should be able to find them.
Ed
Johnny N #1342486 01/16/2020 9:01 PM
I'd suggest finding a tie rod with the proper taper and turning and rethreading the shank to match the turnbuckle sleeve you have. It would be much safer than welding on the Pitman arm. PM me if you want to explore that possibility a little further. I can probably do the threading.
Johnny N #1342489 01/16/2020 9:12 PM
Yes I'll do some more searching. I am using the part #s that they listed in the tech tips. back to the drawing board. Thank you guys one and all. And Jerry yes I'll let you know. Thanks
1949 gmc 1-ton
Johnny N #1342490 01/16/2020 9:14 PM
I'll also make sure the little lady does the 1st test drive!!!!
1949 gmc 1-ton
EdPruss #1342968 01/20/2020 5:27 PM
I believe its Barnes 4wd that you're looking for
https://www.barnes4wd.com/Tapered-Steering-Knuckle-Insert_p_510.html
1951 Chevy 292 Project
Johnny N #1342996 01/20/2020 7:59 PM
Yep, that is them.
Ed
Johnny N #1342998 01/20/2020 8:17 PM
Thanks. Got a couple ordered. Hope they fit. Thanks again
1949 gmc 1-ton
Johnny N #1343007 01/20/2020 9:04 PM
One will and one won't if you bought the parts in the tech tip as they have different taper angles. I posted my adventure with this upgrade here:
https://www.stovebolt.com/ubbthreads/ubbthreads.php?ubb=showflat&Main=128898&Number=873426
A welder that knows what he's doing will have no problem filling in the hole in the pitman arm.
You Tube
Johnny N #1343009 01/20/2020 9:42 PM
Thanks for the info. Exactly the problem I'm having. Good info on your other post
1949 gmc 1-ton
