| | | Forums66 Topics128,185 Posts1,057,203 Members48,465 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2004 Posts: 1,897 Shop Shark | | Shop Shark Joined: Dec 2004 Posts: 1,897 | Is it practical to redrill the axle flange of a 5 lug to convert it to a 6 lug? seems to me any 5 lug you would find would have a much smaller axle flange than a 6 lug. Took a couple of measurements of my Rubicon Wrangler... Looks pretty close to working in my 40. Jeep axles are ez to get! | | | | | Joined: Oct 2005 Posts: 4,261 "Hey! I sound like Darth Vader!! | | "Hey! I sound like Darth Vader!! Joined: Oct 2005 Posts: 4,261 | | | | | | Joined: Mar 2005 Posts: 1,029 Member | | Member Joined: Mar 2005 Posts: 1,029 | Your wheels should fit on Nissan pickup axles. | | | | | Joined: Oct 2003 Posts: 363 Member | | Member Joined: Oct 2003 Posts: 363 | Originally posted by Baldy: Your wheels should fit on Nissan pickup axles. or Toyota axles which are about the right width and lockers and rear disc brake kits are cheap for toyotas. Or get some 5 to 6 lug adapters swingdaddy, you are overthinking this rear end swap | | | | | Joined: Dec 2004 Posts: 1,897 Shop Shark | | Shop Shark Joined: Dec 2004 Posts: 1,897 | Maybe I am overthinking this swap, but as I do not have a good shop to let this sit at while I try to iron out the bugs, I am trying to get as much 411 as possible, find a solution(s) that works for my budget and timeline, gather all parts needed for swap, and get it right the first time.
I have a virtually unmolested 1940 gmc. The truck runs... But I would not drive it more than a couple of blocks. It needs everthing including brakes.
I would like to swap the 228 for the 302 I have, change the 3 speed to a 5 speed, swap out rear axle to an open driveline axle, and address all the brakes at the same time. It just seems like less work to do it all at once.
John | | |
