1 members (tesa), 142 guests, and 2 robots.
Topics128,080
Posts1,055,953
Members48,430
#1341772 01/12/2020 9:08 PM
Has anyone tried a new carter mechanical pump on their 235?
There are two flavors I'm aware of from summit or rockauto:
Carter 2118
Carter 2999
I have the 2999 and cannot figure out a good way to thread onto it.
Both pumps are listed as 1/8-27 NPSF on rockauto... but I can't find any adapter that size. My fuel lines are 5/16 with 1/2-20 threads on their flare fittings.
Right now I'm using a 1/8npt to 1/2-20 flare adapter, but the 1/8npt doesn't seal without the aid of JB weld.
What thread sizes do you guys have on your fuel lines & pumps?
'59 Chevy Suburban, NAPCO
The 1/8-27 is known otherwise as "1/8" Pipe". It has a tapered thread, and requires some type of thread sealer to prevent leakage. I prefer to use a flexible, non-hardening sealer like Permatex Super 300. It was developed in the 1950's to seal aviation gasoline fittings, and it works better then the Permatex 3D, which is also a non-hardening brush-on sealer. It's best to avoid Teflon pipe tape on gas like fittings, as slivers of the tape can get into the fuel system and clog carburetor passages or keep float valves from working properly. The most common adapter fitting for fuel lines has a 1/8" pipe male thread, and a 1/4" or 5/16" "inverted flare" on the other end.
What Jerry said.
NPSF = National Pipe Size Female (more commonly indicated as NPTF for National PIpe Thread Female).
Adapters are easy to find at nearly any FLAPS or Hardware store.
Another sealer would be "Gasoilia" made specifically for fuel and gasoline. Pipe threads will seal without a sealer, but you have to tighten them till your eyes bug out or the female fitting cracks. Without a sealer, you also run the risk of galling the threads. Bottom line is use a sealer (not JB Weld).
My eyes are already bugging out due to how many types of threaded pipe joints there are big_eek
However, your replies helped a lot.
Thanks!
Originally Posted by klhansen
What Jerry said.
Not exactly...NPTF threads are designed to work without sealers. The "F" stands for fuel and is designated a dryseal thread due to the root and crest of the thread being taller than standard NPT which is designed to be used with some type of sealant.
You Tube
NPSF= national pipe straight fuel.
NPTF=national pipe taper fuel
1949 gmc 1-ton
I did not know that. Thanks for the info.
So the OP needs to find a NPSF male adapter. Or will a NPTF adapter work?
ok... i think i found something:
https://www.mscdirect.com/product/details/53567848
that is, assuming a nptf fitting will play nicer with my npsf pump than my current npt fitting.
