5 members (Hotrod Lincoln, Gray_Ghost, 78buckshot, Pete O, 1 invisible), 309 guests, and 6 robots.
Topics128,156
Posts1,057,021
Members48,460
Does anybody have the specific dimensions of the axle shafts for the 1942 Chevy 3/4 ton rear end? Considering custom axle shafts but, would like to avoid having to pull the axles out of my truck to measure them. Thanks for any help.
Ghost Rider
Little Egg Harbor, NJ
1942 Chevy 3/4 ton pickup, 1962 235, Offy intake, Fenton headers, Dual Carter YFs, 1984 T5
1956 Chevy 3100 Apache, 67 350SBC, Saginaw 4 speed, 69 12 bolt
Thanks for your help. Interestingly, there is no specific listing for the 3/4 ton truck axle shaft in the 1942-46 series. While they are listed separately in other years. The only thing close is the listing for "commercial" in this date range. Since the 3/4 and 1 ton were the same, I have to assume this means the listing for "commercial" refers to these axle shafts. I'll do a bit more research to try to confirm this by part numbers. Thanks again for your help.
Ghost Rider
I was not much help, Ghost Rider
Let's hope that someone else has info?
