3 members (Sjm, Forty9, 1 invisible), 90 guests, and 3 robots.
Topics128,264
Posts1,058,356
Members48,485
#134080 03/19/2006 3:07 AM
Thought I'd show you guys what I've been up to this winter. Ressurection and redirection always beats the salvage yard for these kewl trucks. Heres my website: http://www.geocities.com/pickinjim1/Jims51truck.html
#134081 03/19/2006 3:40 AM
jimmy,
Why is the cab so franken high compared to the motor placement?
1950 Chevy p\u 3100. lt1 Corvette powered.
Owner\ autoglass unlimited/Ultra Clear Body Shield
Cowboys creo: taste your words before you spit them out
http://s202.photobucket.com/albums/aa180/getm24_2000/
#134082 03/19/2006 3:58 AM
Hey Wilbur. The motor is in the same position as the original 401. The body sits up because the Wagoneer frame has quite a kickup over the rear axle. In order to get the bed and cab on the same level we had to build a subframe. 11" worth. We have added one ton axles and a slightly heavier drivetrain we should not be top heavy at all.
#134083 03/20/2006 2:51 AM
Nice Job Jimmyjeep.That will kick some [censored].The boys on TV show trucks should see your monster.Maybe you can give them a few pointers. cool cool cool
dan-pa
