| | | Forums66 Topics128,264 Posts1,058,355 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2004 Posts: 73 Member | | Member Joined: Jun 2004 Posts: 73 | Thought I'd show you guys what I've been up to this winter. Ressurection and redirection always beats the salvage yard for these kewl trucks. Heres my website: http://www.geocities.com/pickinjim1/Jims51truck.html | | | | | Joined: Jul 2004 Posts: 427 Shop Shark | | Shop Shark Joined: Jul 2004 Posts: 427 | jimmy, Why is the cab so franken high compared to the motor placement? | | | | | Joined: Jun 2004 Posts: 73 Member | | Member Joined: Jun 2004 Posts: 73 | Hey Wilbur. The motor is in the same position as the original 401. The body sits up because the Wagoneer frame has quite a kickup over the rear axle. In order to get the bed and cab on the same level we had to build a subframe. 11" worth. We have added one ton axles and a slightly heavier drivetrain we should not be top heavy at all. | | | | | Joined: Oct 2003 Posts: 445 Shop Shark | | Shop Shark Joined: Oct 2003 Posts: 445 |
dan-pa
