Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
4 members (Ponchogl, Otto Skorzeny, truckernix, TooMany2count), 122 guests, and 1 robot.
Topics128,277
Posts1,058,453
Members48,490
It doesn't look like any of the usual sources have this weatherstrip for the back of my clamshell burb.
I can only find seals marketed for the barn door versions.
Does anyone know where I can get it?
Is there some other seal that can be re-purposed?
'59 Chevy Suburban, NAPCO
Steele Rubber Products
Martin,
Did you find the type of seal for Ott3r’s type of door : end-gate/lift-gate (clam shell)?
I think that Steele lists only one type - for the “barn doors”?
If contacted they will provide assistance in picking the closest profile to “original” which should be undetectable to the untrained eye.
Thanks for the tips!
I'll send them a note.
Logan
