7 members (ShopRag, KEVINSKI, Peggy M, Otto Skorzeny, Hotrod Lincoln, 1955 1 Series, 69Cuda),
152
Mod | | | Forums66 Topics128,267 Posts1,058,373 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2004 Posts: 73 Member | | Member Joined: Jun 2004 Posts: 73 | Hey all. If there is one word of advice I could give folks thinking about a frame swap, is to compare the frame rises. My 51 GMC 1/2 ton had a really flat frame, so the cab and bed sat on the same level. More or less. When I mounted the body onto its new frame, I had to account for an 11 inch rise over the rear axle. I literally had to add an 11 inch substructure to get the cab and bed on the same plane. So take this into consideration when your frame shopping. You can see the truck here: http://www.geocities.com/pickinjim1/Jims51truck.html | | | | | Joined: Jan 2002 Posts: 866 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 866 | Jimmy, Our 53 was on a 64 wagoneer frame, didn't have that problem, you can see it on our site. We have since gone back to an original frame with mustang 11 front suspension. We did buy it on that wagoneer frame, 4 wheel drive, 360 amc, truck drive line. | | |
