9 members (3B, BarryP, Ribside, DadsFirstPickup, Ol' Red, Donf, Biermann, Jon G, UtahYork), 142 guests, and 2 robots.
Topics128,134
Posts1,056,738
Members48,454
Junior Member
Junior Member
Went to MorTec with the casting numbers from my block.
Looked up: 3970010
and this came up:
3970010....302.....69....4...Z-28 Camaro
3970010....327.....69....2...Trucks and industrial
3970010....350...69-80...2 or 4
(1)what do the numbers for "main cap bolts" mean? :confused:
(2) Any way to narrow this down?
All I really want to do is figure out what kind of engine I have.(you know parts and other good stuff) grin
Please remember I am really new at this. grin
Thanks to all in advance!
jcf
Caps are what hold the crank in. Some were 2 bolt, some were four. The four being the stronger version. Too narrow it down, do the same with the head numbers at Mortec. The combination of both numbers will narrow down the application. If you don't have the heads, don't worry. Your block is part of the Chevy small block series. Almost any part for a small block will fit.
If you want to get technical, you could measure the bore. There were only so many bore / stroke combinations. So you could really narrow down the size of your engine.
If the block is a 350 then it should have 5.7L cast into the block just behind the drivers side cylinder head.
Quote
Originally posted by Adramelech:
and this came up:
Those three motors all have some things in common. They use the same size journal crank and the same bore.
If there is a number stamped in the block in front of the passenger side head it might clarifiy the original application.
Casting numbers from the head might help.
Measuring the stroke would be conclusive. A 302 has a 3 inch stroke, a 327 has a 3.25 inch stroke and a 350 has a 3.48 inch stroke.
The newest option is 26 years old, so it would not be wise to assume the heads, crank, rods or pistons are original.
You have a typical large journal 4-inch block. The heads and crank might make it special and might not. Most likely its a generic 350.
Junior Member
Junior Member
Thanks to all for all the great info.
Hopefully one day I can return some favours wink
jcf
Custom Title
Custom Title
My vote is for a 350. The 302's and 327 industrials are both very rare. That's a popular casting number for race engine, all of mine shared that casting. If you can take it apart, look under the timing cover for the numbers 010 or 020. These are indicators that extra tin or nickel were added to the cast iron, making for a very strong block.
49 Chevy 3600
65 Chevy K10
48 International KB-1 Service Truck
55 Willys CJ5 - Chevy 331 powered
26 Model T Roadster Rat Rod
70 Tucker Sno-Cat 442-A
96 Dodge 3500 Cummins dually flatbed x-cab 4x4
06 Jeep Wrangler LJ rock crawler
If you can't fix it with a hammer, it's an electrical problem
Junior Member
Junior Member
thats the same casting on my block. 2 bolt main 4" bore. I've got aluminum heads from an L98 corvette on mine however.
