0 members (), 107 guests, and 2 robots.
Topics128,265
Posts1,058,365
Members48,485
#1340425 01/04/2020 2:18 PM
has anybody installed new wiring harness with fuse block under seat?I am wanting to do something similar.can't seem to locate the posting.
Thanks for any help
Danny
1958 GMC stepside GMC 302 six cylinder 3 speed OD trans
dtwbcs #1340468 01/04/2020 9:13 PM
Insomniac
Insomniac
Why would you want to do that? Best place for the fuse block is on the firewall.
Gord 🇨🇦
1954 1/2 ton 235 4 speed
dtwbcs #1340471 01/04/2020 9:19 PM
Sir Searchalot
Sir Searchalot
Thanks for any help
Yes, some do that on AD trucks because it makes more since to them. I've never had an AD truck. So not sure why.
I've had 55.2 and up. Seems you have a 1958. The fuse panel goes on the inside of firewall and uses some of the driver side hood hinge stick thru bolts. Under the seat would be a very bad idea on a 55.2-59 (TF truck). If that's the truck you are asking about.
Your question indicates you may need further instruction on installing a harness. Glad to help if needed.
dtwbcs #1340474 01/04/2020 9:34 PM
I agree that under the seat isn't a great spot for a fuse block. It's liable to get damaged from crap stored under the seat if it isn't a covered type (Blue Sea Systems makes very nice covered type fuse blocks). And it means you have to route wires to it and back to the firewall area where the power is needed.
dtwbcs #1340483 01/04/2020 10:39 PM
Sir Searchalot
Sir Searchalot
The best idea is to buy a prewired (to a ATO fuse block), harness. On TF trucks, place inside, upper left of left foot area.
Painless. EZ Wire, American AutoWire, etc. Stick with well known brands at well known vendors
bartamos #1340486 01/04/2020 11:01 PM
Ok guys thanks for the feedback.I was thinking easier to access.Trying to twist around up under there like a pretzel isn't any fun. Maybe leave enough to where it could be dropped down? if ever needed?? ohwell
yes, i agree but apita to access/check... frown
Danny
dtwbcs #1340519 01/05/2020 1:43 AM
Sir Searchalot
Sir Searchalot
Nothing to access after install. Check fuses only if something happens. reach in, pull out with a tool and look at them. Not as big a deal as you think. Under dash wiring is the same no matter where fuse panel is. EVERYBODY puts the fuse panel above dimmer switch on TF as explained. We would not steer you wrong.
dtwbcs #1340531 01/05/2020 2:50 AM
Thanks cool
Danny
dtwbcs #1340533 01/05/2020 2:56 AM
Crusing in the Passing Lane
I agree that it is awkward to reach a fuse panel above the dimmer switch, but it is also for dirt, water, loose tools, etc., to reach there.
Ed
