1 members (J Lucas), 85 guests, and 3 robots.
Topics128,024
Posts1,055,395
Members48,422
#134037 03/11/2006 9:57 PM
I am curious to know what some of you hot rodders are doing to make these trucks handle. I know I am changing the rear suspension around. Not that I doubt the truck arm suspension, most of us know they are running a similar set up in Nascar, but it's to make more room. I plan on doing something similar to what is in my Camaro http://www.pro-touring.com/forum/showthread.php?t=14014
I would mount the LCA's under the frame rail and make a new simple crossmember for the 3rd link. I'm doing this to make more room under the bed. The 63 is going to be my tow truck so I would like to put a fuel cell in back and mount a compressor and air tank under the bed to run air tools at the track and work the bags.
I mainly want to know what is out there for the front end. Will other things like Camaro front suspension work on it (UCA's and LCA's)?
Thanks in advance.
1963 Chevy P/U: Forged LS1/4L80E swap and big hit of N20 coming
1973 Camaro: Low compression solid roller LS1 with PT91 turbo Built for the Silver State classic
1967 Convert Continental: Stock Cruiser
#134038 03/11/2006 11:13 PM
Don't know if this is a help or not but I am air bagged all around with 1 1/4 sway bars front and rear and I handle like a champ. good shocks also help.
#134039 03/12/2006 5:43 PM
Riding in the Passing Lane
I agree with Gazim. These trucks have a good front end. I use the big heavy duty shocks from Monroe (napa) & a sway bar.
1972 Chevy c10 Cheyenne Super
