0 members (), 125 guests, and 10 robots.
Topics128,186
Posts1,057,211
Members48,465
Hello,
my PU is build 1953 and on the rear axle on the driver side is oil coming out. What an it be? And where do I find a technical drawing of the real axle so I can see what kind of seal may be damaged.
Ask
Wolfgang
I'm working on a Chevy Pickup 3600, build 1953 with an 235 cui engine.
Here you can watch my truck: https://www.kripahle-online.de/unterricht/?page_id=2532
Julian Carter
1970 Triumph GT6
1967 Triumph TR4A
1952 Chevy 3600
1948 MG-TC
Hello Julian,
there is no technical drawing.
Wolfgang
Sir Searchalot
Sir Searchalot
Probably this
National 414045, sold by many vendors including Amazon. This may be what is leaking if you are talking about leaking oil near brake plate area. It will fit 1953 3100.
The Procedure for 1954 is here. (may be same for 1953)
The other link from Julian is for up to 1951.
Here is an exploded view that was found on Stovebolt forum. Scroll down to last post by Jorb and click on the link. Seal 5.822. That is a the parts catalog number which is just for reference. It would get you to the part number, but all those old part numbers have been changed many times, so use the National Part number or equivalent.
Check to see if there is any noticeable up and down motion of the axle while picking up on the end of the axle. If there is, you will also need new bearings and/or new axles,
A new seal won't seal if the bearing/axle is excessively worn.
What tonnage is your 1953 ?
Below is
1/2 ton exploded view
Sir Searchalot
Sir Searchalot
Below is
Already posted that and gave you credit.
What tonnage is your 1953 ? Below is 1/2 ton exploded view
Thanks for the credit, I guess you could say my credit rating went up. :-)
Sir Searchalot
Sir Searchalot
Waiting for Wolfgang to reappear.
"Wolfgang". I shouda named one of my boys Wolfgang. Great "Irish" name!
