| | | Forums66 Topics128,197 Posts1,057,267 Members48,466 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2009 Posts: 171 'Bolter | | 'Bolter Joined: Oct 2009 Posts: 171 | Hello, my PU is build 1953 and on the rear axle on the driver side is oil coming out. What an it be? And where do I find a technical drawing of the real axle so I can see what kind of seal may be damaged. Ask Wolfgang | | | | | Joined: Dec 2014 Posts: 357 'Bolter | | 'Bolter Joined: Dec 2014 Posts: 357 |
Julian Carter
1970 Triumph GT6 1967 Triumph TR4A 1952 Chevy 3600 1948 MG-TC
| | | | | Joined: Oct 2009 Posts: 171 'Bolter | | 'Bolter Joined: Oct 2009 Posts: 171 | Hello Julian, there is no technical drawing. Wolfgang | | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 | Probably thisNational 414045, sold by many vendors including Amazon. This may be what is leaking if you are talking about leaking oil near brake plate area. It will fit 1953 3100. The Procedure for 1954 is here. (may be same for 1953) The other link from Julian is for up to 1951. Here is an exploded view that was found on Stovebolt forum. Scroll down to last post by Jorb and click on the link. Seal 5.822. That is a the parts catalog number which is just for reference. It would get you to the part number, but all those old part numbers have been changed many times, so use the National Part number or equivalent.
Right is right, even if everyone is against it, and wrong is wrong, even if everyone is for it. - William Penn | | | | | Joined: Mar 2010 Posts: 10,308 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,308 | Check to see if there is any noticeable up and down motion of the axle while picking up on the end of the axle. If there is, you will also need new bearings and/or new axles, A new seal won't seal if the bearing/axle is excessively worn.
| | | | | Joined: Mar 2011 Posts: 1,146 Shop Shark | | Shop Shark Joined: Mar 2011 Posts: 1,146 | What tonnage is your 1953 ? Below is 1/2 ton exploded view | | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 | Already posted that and gave you credit.
Right is right, even if everyone is against it, and wrong is wrong, even if everyone is for it. - William Penn | | | | | Joined: Mar 2011 Posts: 1,146 Shop Shark | | Shop Shark Joined: Mar 2011 Posts: 1,146 | Already posted that and gave you credit. Thanks for the credit, I guess you could say my credit rating went up. :-) | | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 | Waiting for Wolfgang to reappear.
Right is right, even if everyone is against it, and wrong is wrong, even if everyone is for it. - William Penn | | | | | Joined: Mar 2010 Posts: 10,308 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,308 | "Wolfgang". I shouda named one of my boys Wolfgang. Great "Irish" name!
