4 members (rfs56trk, FAST55, delwrench, RaNfLaS), 214 guests, and 4 robots.
Topics128,086
Posts1,056,101
Members48,434
#1338970 12/24/2019 3:23 PM
I have a 5700 COE with a Carter BB-2 updraft carb on a 261ci. When searching the web for Carter BB-2, nothing comes up, only BB-1 and BBR (BBR-2s). Hemmings has an article from 2011 describing BB 1, 2 and 3 size units. The BB size 2 has a 1 1/4-inch bore with a 211/16-inch mounting base. Is that describing the BB-2? Where is the serial number located to get a rebuild kit.
3B Offline
Hy Patina 54, welcome and Merry Christmas. I did some research last night and the Carter updraft seems to have fallen through the cracks even in most of my GM parts books. I did find one book that listed the carb and luckily the manufacturers part number for it, the number they referenced was BB1-871-SC. Once I had a part number I found a carburetor kit listed at the Carburetor Doctor, their part number CK476 $39.95, hope that helps.
And a Merry Christmas to you. Thanks for the lookup and info. I have a lot to learn about the '55 1st series 5700 COE.
1954, and 55 1st series Chevrolet COEs, came standard with a Carter model 2075 updraft carburetor. The Carter model 871s, were on 50-53 models. Main difference is, the 2075s face forward, because of the air cleaner being under the hood, versus the 871 carb., facing rearward, because of the air cleaner being mounted under the cab floor.
Spanky Hardy
More pictures on Photobucket
1950 GMC 250 1-Ton
Moderator, Great Lakes Bolters
1 Offline
Spanky,
Great info.
Next question is....where would we find a Carter model 2075 to purchase?
I don't believe the one that Patina54 has will be able to be rebuilt.
Thanks!
--Tom
Place a "parts wanted" ad in the Swap Meet?
Happy New Year
1 Offline
Ah, yes...good point. Thanks!
Sometimes the obvious answers are the hardest to find...
--Tom
