Fixing the old truck
BUSY BOLTERS
Are you one?
Where is it?? The Shop Area
4 members (Mike Lee, Dakota38, Guitplayer, chaz71), 513 guests, and 1 robot.
Topics126,777
Posts1,039,270
Members48,100
Most Online2,175
Jul 21st, 2025
Hello. I know this may sound like a dumb question but on my 1947 the tank is underneath the bed on the driver's side and the filler neck goes through the side of the bed just behind the cab. I have seen several pictures of what say they are 47's but the filler neck seem to be in different places. How did it come from the factory? Thanks
1947 3100
The 1947.5 half-ton truck and the 1948 truck have the fuel tank under the bed and the filler neck goes out of the bed just behind the cab on the passenger (right) side. The tank was moved inside the cab in 1949.
Not sure how mine ended up on the drivers side. Thanks for the response!
1947 3100
My ‘47 is mounted on the drivers side also.🛠
This is interesting. We have always put the filler on the passenger side when we make bedsides for that truck. We have an original bedside with the filler on the passenger side and we used it for the pattern. It looks like more research is needed.
Mar-Ktech
Very interesting indeed.. some 1947 trucks had the filler on the right and some on the left? ..My 1947 clearly had the filler on the right.
Is there an illustration in Brad's links that shows the fuel-tank filler on the left side?
Former BMW Rider
Former BMW Rider
My '47.2 is a passenger side fuel filler.......
Andy
His: 1947 Chevrolet 3104
Hers: 2008 American Saddlebred
"I proudly Stand for the Flag and Kneel for the Cross" Unknown
The 1947-48 Salesman data books do not refer to side but state they are an inside frame placement, export perhaps?
1947 Truck Specifications Manual - Page 93 - fuel tank was clamped to the outer side of the right-side frame member - on all 1947 trucks.
Filler location on right side - for all USA trucks.
1948 Truck Specifications Manual - Page 93 - fuel tank inside of frame for small trucks (3100-3800) and outside of right frame member on large trucks.
Could they be using up driver's-side-fill tanks left over from earlier trucks? (Probably not.)
Mine's on the passenger side but it has a home-made wooden flatbed.
33 Years. Now with a '61 261, 848 head, Rochester Monojet carb, SM420 4-speed, 4.10 rear, dual reservoir MC, Bendix up front, 235/85R16 tires, 12-volt w/alternator, electric wipers and a modern radio in the glove box.
A 47.1 we did 30 years ago with driver side filler neck. Neck and tank were rusted so we made a new tank and used a straight filler neck but the frame mount brackets were a reverse image of factory passenger side mounts and hole in the bed was factory looking. Might be something to the export idea.
[img]https://i.postimg.cc/7fjn11s3/Trigger-005.jpg[/img]
Evan
S 10 frames put the gas tank on driver side
(Release build 20240826)
Responsive Width:
PHP: 8.3.11 Page Time: 0.051s Queries: 16 (0.046s) Memory: 0.6552 MB (Peak: 0.7727 MB) Data Comp: Zlib Server Time: 2025-09-22 11:13:35 UTC
Valid HTML 5 and Valid CSS
